Question about Canon imageCLASS D340 All-In-One Laser Printer
Blurry copies, no error code - Canon imageCLASS D340 All-In-One Laser Printer
Blurry copies
clean ur leser mirror&full gradiation adjust
Feb 08, 2013 | Canon imageRUNNER iR C4080 Color Copier
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
I have a toshiba estudio 650, I came to work from the weekend today, and the unit prints stretchy text, and a little blurry... I print diag page and it prints good, I use the scanner to copy or scan, and...
It defiantly sounds to me like the optics are to blame, if you remove the platen glass you will be able to clean the optics very gently with a glass cleaner just to pull the dust particals off :)
Aug 18, 2009 | Toshiba 6560 Copier
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Jan 30, 2009 | HP LaserJet 3050 All-In-One Printer
Laser Printer Copies Blurry
are copies blurry? from the glass or printing? clean the glass, and optics. and the machine could probably use a calibration..
May 16, 2008 | Office Equipment & Supplies
Blur copys
The 1015 / 1120 were prone to the lens drive gear cracking, and not holding to the shaft.
Sometimes you will get a lens initializing error, sometimes you wont.
But this is most likely the problem.
Feb 01, 2008 | Konica 7410 Laser Printer
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
Canon imageCLASS D340 All-In-One Laser Printer Logo
23 people viewed this question
old marine
old marine
