Question about Fossil Blue watch #AM3574 Watch for Men
Fossil arkitekt me1005 - Fossil Blue watch #AM3574 Watch for Men
SOURCE: I have the Fossil FS-4154,
Did you put the protective cover back over the battery? sounds like a grounding problem.
Posted on Sep 22, 2008
escapement
  • 2334 Answers
SOURCE: REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
slp11508
  • 43 Answers
SOURCE: remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Posted on Jan 14, 2009
  • 12650 Answers
SOURCE: lengthen band
to make longer have to add a link-contact them 800-842-8621 will ask for info on back of watch
Posted on Nov 26, 2009
mcdevito75
  • 1970 Answers
SOURCE: i have a fossil arkitekt how do u take the back of
mcdevito75 here, Look very closely at the back cover for any groove that line up with the case and the back of the watch, if so place a sharp blade knife in that groove and gently twist cover off. Also look for a small tab comming off the back cover, if so the knife blade ios placed under it and gently twisted to remove back cover.If by chance you see square type holes around the edge of the back cover then it"s a screw on back and you"d need a special tool to un-screwit, see a small watch repair shop for this type of back cover.
Posted on Jul 05, 2010
Where could I find an owners manual for Fossil Arkitekt FS-2934 ?
Try Googling (fossil)(FS-2934)(manual) without parens.
Jul 17, 2017 | Fossil Watches
HOW TO REPLACE BATTERYIN MY FOSSIL ARKITEKT WATCH
Take your watch to a jeweler for battery replacement.
Feb 15, 2014 | Fossil Arkitekt watch
I am trying to find extra links for the band, it is too tight, I need 2. I have searched all the web sights I can find with no luck. The watch is a Fossil ARKITEKT FS-3003.
You can get links from the maker.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html and you will see a menu on the left.
Under "Product info" you will see "ordering links and bands", click on this and follow the instructions.
Jan 08, 2011 | Fossil Watches
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
Can't find the watch band for fossil arkitekt fs 4127?? it have a curve and use two pins
I have the same watch Fossil FS-4127 and I too can't find a replacement band. Appears to be planned obsolesence by Fossil. This FixYa site is almost as bad as Fossil, which is all advertisements and no answers whatsoever.
Jan 03, 2010 | Frontgate Watches
Can't get back off to change battery, even with special tool
Looking at the Fossil site, I couldn't find "Arkitekt blue" as a description.
I noted that they have a blue one which is automatic (i.e. self winding) and therefore does not need winding - but it does need to be worn to keep the spring wound up.
The Fossil site has a complete list of their models and selecting one gives you all the details of the watch, including manuals.
I suggest you try a search on the web site.
Jan 02, 2010 | Fossil Arkitekt watch
Lengthen band
Nov 26, 2009 | Fossil Arkitekt Stainless Steel ! Watch...
Remove links from fossil metal band
Jan 09, 2009 | Fossil Arkitekt watch
Fossil Blue watch #AM3574 Watch for Men Logo
61 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
