Question about Stanley Bostitch 00540: 00540 AntiJam ? Extra Heavy-Duty Stapler
Cannot release staples - Stanley Bostitch 00540: 00540 AntiJam ? Extra Heavy-Duty Stapler
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
How do you release the handle of this gun
I am in the same boat, have no idea how to release the handle of this horrid Arrow T50. Staples are loaded but the lever is fixed and can't use it...of course the manual mentions nothing.
May 27, 2013 | Staples Swingline® 36115 Staple Guns Tools...
How do you put staples in
There is a thumb release lever that keeps the slide bar locked down. Take your thumb and push up ******* this plastic release and it should open so that you can add staples.
Aug 27, 2011 | Stanley Tools TRE550 Electric Staple/Brad...
How do i open the stanley tr110 staple gun to load the staples
Angelbabie...Like most things, it's pretty easy if you know how.
1.Release the loading latch located on the back end of the staple gun by pinching it with your thumb in a downward motion. This will release the catch and allow you to pull the loading slide out.
2.Hold the gun upside down (so the staple don't fall out) and place a stick of staples in the bottom of the channel which will be exposed once you pull back the loading slide.
3.Push the slide back in and make sure the latch is engaged. All good to go!
Happy stapling.
Mar 01, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
I have an older Fasco stapler, it is orange in color. S3G 16 is number on it. The part that pushes out the staple has a piece of staple stuck in it. How can I get this out?
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Nov 30, 2010 | Fasco 9 Narrow Crown Pneumatic Staple Gun
Have a Electric Stapler B8E E66760. Won't kick out to load staples
pretty simple. Take off the plastic cover, at the front where it staples will be a black metal piece on top of the stapling area. That is the front clip release. Release the staple tray like you would normally with the button and also Push the top black piece back to detach it from the staple tray. It should spring out then. Clean around it with alcohol and keep the cover off. Push it back in place, release it a few more times to make sure it works correctly now, then put the screws back in.
Oct 04, 2010 | Office Equipment & Supplies
I cannot figure out how to load an Arrow T50P staple gun
Turn it upside down. On the end opposite where the staple comes out look for a tab on each side you squeeze to release the staple holder, the staples go in to this holder upside down as well, just push it back in until the releases catch and hold it in. Hope this helps.
Jun 17, 2010 | Arrow T50P ARROW STAPLE GUN
Jammed staple-need to remove top of gun to remove
pull all staples out and take a screw driver and hammer drive the plunger back down into stapler till the hung staple is released
Nov 04, 2009 | Arrow T25 Staple Gun
Replacing staples
If I remember correctly, you open the cover and there should be a release handle, the staple unit will swing/ slide out , gently grasp the used staple cart. and while pushing down and pulling out. Install new staples.
Dec 20, 2008 | Toshiba e-STUDIO 282 Black and White...
Stanley Bostitch 00540: 00540 AntiJam ? Extra Heavy-Duty Stapler Logo
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
