Question about Sansui DTV2760 27" TV
Video format SN: 065360804505
I want to play PAL formatted DVD's on this TV. Given the appropriate DVD player, will this unit play the PAL DVD?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
On the back side of dvd one switch is given to change over the system. please check it. after change you will be able to play dvd on PAL
Posted on Sep 29, 2007
I cant play pal formatted discs on my dvd player
PAL is the European format and will only work in PAL DVD players. You need to either get a NTSC (US) formated disc or a PAL formatted DVD player.
May 03, 2011 | Televison & Video
What format is used when the VHS is copied to the DVD ? I have copied the VHS tapes onto Verbatim DVD-R discs. They will not play on my computer. Verbatim says I need to know what format they are in...
the most common in the US is NTFS. another used in other countrys is PAL. the format is seperated into regions, and they are as follows,
REGION 1 -- USA, Canada
REGION 2 -- Japan, Europe, South Africa, Middle East, Greenland
REGION 3 -- S.Korea, Taiwan, Hong Kong, Parts of South East Asia
REGION 4 -- Australia, New Zealand, Latin America (including Mexico)
REGION 5 -- Eastern Europe, Russia, India, Africa
REGION 6 -- China
REGION 7 -- Reserved for Unspecified Special Use
REGION 8 -- Reserved for Cruise Ships, Airlines, etc...
REGION 0 or REGION ALL -- Discs are uncoded and can be played Worldwide, however, PAL discs must be played in a PAL-compatible unit and NTSC discs must be played in an NTSC-compatible unit.
you can use MAGICdvdRIPPER softwareon your computer, it works with NTSC, and PAL formats and vice versa.
Jan 28, 2011 | Samsung DVD-VR320 DVD Recorder/VCR
Can't play american DVD
U from Europe,Asia or the Middle East?Yes.Ur Blu-Ray player play only DVD disc in PAL format.U bought American DVD disc in the United States?Yes.U can't play american DVD disc in ur Blu-Ray player?Because the US American DVD disc u bought in the United State play only in the NTSC format.
Oct 26, 2010 | Sharp Aquos BDHP50 Blu-Ray Player
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
My new "panasonic" dmp bd80 not support the PAL DVD format and can't play some DivX disks. Can you give some solution to solve the problem?
Check the dvd player settings. Try and switch the dvd player itself to NT instead of pal.
Some newer DVD Players also play videos in the MPEG-4 ASP video compression format (such as DivX) popular in the Internet, as well as the RMVB video compression format.
Check any settings on dvd player to switch format output, or check tv settings so it accepts all formats.
Nov 23, 2009 | Televison & Video
APEX DIGITAL AD-1500 unit
It play all regions in US an Canada it in NTSC software format.All US,and Canada in softwares it this regions.Europe in PAL regions,and Asia play in that format PAL too .
Aug 25, 2009 | Apex Digital AD-1500 DVD Player
DVD disks just play in black and white. No color.
This is because of the audio video format issue. You select the TV type to auto (Advisable) or to the appropriate selection such as PAL or NTSC in the DVD player to get the better output with the color.
This selection you usually find in settings > Video setup> TV Type
Aug 06, 2009 | Zenith XBV443 DVD Player/VCR
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
PET702/37 Connection to PAL TV
this link : http://www.consumer.philips.com/consumer/en/in/consumer/cc/_onlineStoreStatus_false/_productid_PET702_98_IN_CONSUMER/_retailStoreStatus_false/Portable-DVD-Player+PET702-98
features both a leaflet and manual for this model in pdf format.
Jul 07, 2008 | Philips PET702 Portable DVD Player
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Sansui DTV2760 27" TV Logo
87 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
