Question about Panasonic TH Televison & Video
Panasonic tv relay clicks - TH Panasonic Televison & Video
  • Official Brand Answer
  • 350 Answers
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Posted on Oct 23, 2013
Panasonic th-50px60u clicks every 3 seconds from relay on power board
Pull the back off and see if you can see some bulged capacitors if your comfortable doing this, another issue could be bad solder joints on one of the boards, you could try baking each board starting with the power supply board in the oven to see if this corrects it, there are vids on youtube that tell how to bake the boards.
Mar 10, 2018 | Panasonic Televison & Video
Panasonic Viera tc-p60st30 tv will not turn on. No red blinking light. Relay clicks every 10 seconds.
Sep 14, 2013 | Panasonic Viera Plasma TV TC-P60ST30
My Panasonic TC-32LX85 LCD TV powers on but then clicks of and on repeatedly?
The main power regulator board to your TV should be checked. In most cases, it need replacement.
Feb 05, 2013 | Panasonic TC-32LX85 LCD TV
Wont turn on just clicks
The click is the manual relay inside the set------you may have a short somewhere (fuse should be good if power relay clicks) or a loss of high voltage.
Dec 03, 2012 | Panasonic CT-32SL14 32" TV
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
Hi good morning my panasonic sopia tv has a problem on the power button, sometimes will on and sometimes not, what will i do ? thanks
the problem is probably on the on and off botton, if it doesn't click its bad, if it does click when pused in and returns its a good sign it works and relay switches or capacitors need to be examined and exchanged and maybe trnsformers. it could be simple or exchange one item on electronic board
Dec 12, 2010 | Panasonic TC-21S80RQ TV
Hi have a panasonic tv ct36d308 and it dead relay clicks fuse ok
Relay click means stanby power supply working fine pls check the other power supply section and trouble shoot
Aug 26, 2010 | Televison & Video
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Feb 04, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
