Question about Cisco AUDIO-TECHNICA ATR2500-USB CARDIOID CONDENSER USB MICROPHONE
I am having issues getting my audio technica atr2500 usb to work..I finally got it to pick up sound but its extremely quiet on the loudest setting..any help?
I am getting a high pitch poping sound from my atm25 bass drum mic
If this is only when you hit the bass drum, it's picking up feedback from being too far inside the drum or pointed at the wrong part of the head. Use a mic stand and position the mic off to the side, but in front of the head, pointed at the midway point between the center and edge of the drum head. This should eliminate the problem. If the noise is still present, have someone qualified to work on microphones look at it to determine what the problem is.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 13, 2011 | Audio Technica Audio-Technica ATM25...
My Audio-Technica AT4033CL mic worked great up until recently. it has been cutting out and not picking up sound constantly, i have to tap it in order for it to pick sound up again, sometimes it stays...
The most common problem at these cases is a loose of the phantom power. Take a closer look at all the connections and check that the phantom power supply voltage is enabled at the mixer. If it's possible check with a multimeter that you have 48V DC at the 2 - e pins of the XLR connector.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 12, 2011 | Audio Technica Audio-Technica AT4033CL...
My church bought 4 audio technica free way 700 series microphones about a year ago and from the beginning we had problems with them. Now only one of them is working! There is no warranty and we really need...
Audio Technica is generally a good brand name in microphones, but sometimes if you talk to musicians they tend to favor names they are familiar with like Sure. In the church, school, venue world, audio technica is respected. I work audio in three separate venues and we have no trouble with our audio technica microphones.
Have you adjusted the channels--and have you tried to do so manually? Have plugged the working one into the same inputs the nonworking ones were plugged into? I know it sounds like a simple thing to ask, but sometimes the connections to the sound board are the issue. If you have the more advanced receiver for the freeway 700, there are other adjustments designed to allow you to adjust between guitar and voice. If it is preset to guitar it will not sound good for voice. You may have to change that. I am assuming you put in new batteries, but ifyou have not, you may want to try that as wireless mics use up batteries quickly.
Those are a few possibilities. If it is the actual unit, then you can look inside and see if something is loose, but as far as repair, that gets into a whole issue. Hopefully something above helps solve the problem
Sep 06, 2009 | Dual Audio-Technica ATM250DE Microphone
Dr-gx1 mocrophone not picking up sound
From what I can find it doesn't require a power supply. You might have a problem with your adapter.When going from balanced XLR connectors to unbalanced connectors you have to make sure of the proper connections.Theres a good explanation at http://recordingengineering.suite101.com/article.cfm/wire_a_balanced_micro
May 12, 2009 | Audio Technica Audio-Technica DR-GX1...
Compaq Presario CQ70-116ea XP microphone extremely quiet
Have you tried going into the sound management and volume controls?, there should be a slider control to turn up the mic. in there somewhere.
Or updating the sound driver, or rolling back the driver?
I know that you have updated the drivers but I did that and had to roll back as the "new" driver was less than useless.
I hope this helps
May 09, 2009 | Compaq Presario Notebook
Cisco AUDIO-TECHNICA ATR2500-USB CARDIOID CONDENSER USB MICROPHONE Logo
44 people viewed this question
Top Cisco Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
