Question about HP LaserJet P4015N Printer
Change language Language is in dutch, how do I change it to English?
  • 52 Answers
Power off then power on when memory starts counting up press and hold ok button until all three lights stay on release button find language then arrow up or down until english appears and press ok button
Posted on Nov 06, 2013
starcomp
  • 117 Answers
SOURCE: Language problem
hai
to change the language follow these steps.
Usually, the language and country or region are set when you install the,
HP PSC. If you set the country/region or language incorrectly during.
installation, use the following procedure.
1. Press Setup.
2.Press 5, then press 5 again.
This selects Maintenance, and then selects Set Language & Country/
Region.
You are prompted with a list of languages. You can also scroll through
the languages using or .
3 Using the keypad, enter the two-digit number for the desired
language.
4 When prompted, press 1 for Yes or 2 for No.
You are prompted with all the countries/regions for the selected
language. You can also scroll through the countries/regions using
or .
5 Using the keypad, enter the two-digit number for the desired country/
region.
6 When prompted, press 1 for Yes or 2 for No.
7 You can confirm the language and country/region by printing a Self-
Test Report, as follows:
a. Press Setup.
b. Press 1, then press 5.
This selects Print Report, and then selects Self-Test Report.
Posted on Aug 05, 2008
  • 50 Answers
SOURCE: I accidently changed the language now its in dutch i think
Troubleshooting steps to be Followed
Setting the front panel language on the HP PSC 2200 series To set the language and region, follow the steps below:
  1. On the all-in-one front panel, press the Setup button five times, and then press Enter to access the Maintenance settings.
  2. Press the number 5 on the front panel numeric keypad, and then press Enter to access the Language and Region settings.
  3. The available languages will appear in the display. Press the Right Arrow (>) button to scroll through the available languages. Enter the two-digit code for the desired language based on what is listed in the display (example - 11 for English, 12 for Spanish, and etc.).
  4. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the language and try again.
  5. The available regions will appear in the display. Press the Right Arrow (>) button to scroll through the available regions. Enter the two-digit code for the desired region based on what is listed in the display.
  6. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the region and try again.
The front panel language does not set correctly There can be a problem if the front panel cover (bezel) is not installed correctly. If the language cannot be set or is still wrong, do the following:
  1. If the software has not been installed, install it.
  2. Remove the control panel bezel. This may require the use of a coin or small screwdriver to carefully pry up the cover from the back (near the display).
  3. Reinstall the front panel bezel as shown in Figure 1. Be sure the bezel is firmly seated and that all of the buttons can move freely. Figure 1: Installing the front panel bezel c00224430.jpg
  4. Set the front panel language following the steps above.
Posted on Sep 18, 2008
Nikhil Gedam
  • 87 Answers
SOURCE: How to reset Language
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Oct 30, 2008
SOURCE: language changed
Press Menu, go forward (right arrow) to the 4th option (Maintenance), hit enter, hit left arrow once, and enter. This is the language setting. Select language, press start, select country, press start.
Posted on Nov 07, 2008
Evildice
  • 222 Answers
SOURCE: How can I reset the language to dutch if the
read user manual
Posted on Sep 23, 2009
Changing the language from Dutch to English
If you want to change the language of Windows, you should install the English language pack. Of course, you should look for the Language Pack of the Windows version you are using, n ot specified.
Do a search for it at mocrosoft.com
Nov 08, 2015 | Computers & Internet
Need to change language to english/us
is it windows 7 home basic?if it is the only way to change language legaly is to upgrade to ultimate as that has all the languages.there is a programme you can run but it does not change the language of the op system.eg windows 7 dutch would be changed to english but updates will still be dutch.if its ultimate download the language pack from windows update.
Dec 06, 2013 | Acer Computers & Internet
I have just bought a garmin nuvi 1300 and when turned it on the language is german or dutch. We need english but cannot figure out how to change to that seleciton. Help??
can u look for this words here i think it may help you.
Werkzeuge---Tools
sprache---language this is for german language
taal---language
tools--tools this is the same this is dutch language i think it might help
Mar 04, 2011 | Garmin nuvi 1300 Car GPS Receiver
How do I change the language from German to English
Well you may please follow the steps below to change the language to English on TI-84 Plus -
• Press the [APPS] key.
• Under the applications listed select the language currently on the calculator (For example Francais, Espanol, Dutch...) and press [ENTER].
• On the Language Localization screen, the choice to select a language is given. Select English and press [ENTER].
Good Luck!!
Thanks for using FixYa!!
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
Change the language on the garmin nuvi 1300
Mar 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Need to change language settings on Samsung Omnia
yes you can......the question is do you understand dutch?? :D take it to were you got it from and tell em the language is in dutch..they'll probably find somebody
Sep 05, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Change dutch language to english language before instalation
i used kaspersky 2010 and it was in russian.. i used to chage the language by pressing ctrl+shift+alt +f12. try it! it works!
Apr 21, 2009 | Kaspersky Labs Internet Security 2009 Full...
Change operating language
How to change OS language from Dutch to English? The regional settings change only the keyboard, the multilanguage option is not available on ASUS Eee PC's XP Home!!! It is just a localized version: it saya everything in Dutch.
Reinstalling in English, I can not use my clean serial, it does not accept it and also I lose all the drivers...
So how could we REALLY do it?
Apr 13, 2009 | ASUS Eee 4G Notebook
HP LaserJet P4015N Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
