Question about Cobra 29 LTD CB Radio
Fix cobra 29 ltd hook up backwards - Cobra 29 LTD CB Radio
  • christopher
    christopher Oct 22, 2013
    we find the diodethat went out on 29ltd but its not blowin it out when we plug in power cord its blowing out the fuses when we plug power in to it could someone help me and tell me what i need to look for thanks
    Genius:
  • Cobra Master
  • 1,795 Answers
D-23 is your reverse polarity diode.Change it and you'll be ok its a 1n4404
Posted on Oct 28, 2013
3 Suggested Answers
  • 773 Answers
SOURCE: how do i calibrate my cobra 29 ltd classic
When you say calibrate your radio, usually it means you are trying to re align the channels. However I do not believe that is the question you are trying to ask.
I think you are trying to ask is, "How to I tune my antenna?"
You cannot actually tune the radio. What you are probably talking about is your SWR. If so, Here is how to do it.
First make sure you are in an open parking lot. Structures like building, trees and other cars near by can give you a false reading.
Next with the radio on, turn to channel 20.
Make sure all the doors and windows are shut.
Flip the switch that is all the way to the left to CAL.
Key the mic and hold it. Then turn the knob all the way to the right marked SWR CAL up until the needle on the meter is all the way to the right at the little red triangle marked CAL. While still holding the mic key, flip the switch to SWR. The needle should swing back and will give you the SWR reading for that channel.
** try not to make any noise because if its picked up by the mic it will give you a false reading. Try turning the dynamic all the way down so it will not pick up sound."**
now if its 1.5 or lower your in good shape. You could always do better. If its 2 or higher your antenna is not matched. Here is how to tune it.
Use the same steps above to take a reading on channel 1 and 40.
You need to recalibrate each time you take a reading.
Now if the reading on channel 40 is higher then on 1 the antenna is too long. You need to make the antenna shorter. your antenna should have instructions on how to do this.
If it is higher on 1 then 40 its to short, it needs to be longer.
Follow the antenna instructions on how to adjust length.
Now if you really did mean, how do you align your radio, meaning tuning the channels, then you need an oscilloscope and a couple of other meters like a DMM and watt meter etc, and some specialized tools. Its also an involved process. I would suggest taking the radio to a radio shop. You can usually find them at truck stops.
Posted on Jun 17, 2009
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
You should not calibrate the antenna before you install it on the car!! the antenna needs to be calibrated on the vehicle that it is going to be on. Type of vehicle, different mounts, and many other variables can change the amount of reflection you will get.
j0hn9999 did a much better job but left some info out.
Take your SWR readings on channel 1, then on channel 40.... NOW, if your SWR is higher on ch 40 then ch 1, then your antenna is too long and it needs to be shortened. Refer to the antenna instructions on how to shorten the antenna.
If your SWR is higher on ch 1 then on ch 40 then your antenna is too short. You must lengthen the antenna. Again refer to your antenna instructions on how to lengthen your antenna.
You must calibrate each time you take a reading.
Make sure your doors and windows are shut when taking a reading
Make sure you are in an open lot when taking a reading as buildings, trees and other structures can cause reflection and give you an inaccurate reading.
If you adjust the length of your antenna on another vehicle and then put it on yours, the SWR will be off. It will need to be tuned again.
An external meter is better then the one in the radio, but will need to be hooked up in the vehicle you have the antenna on.
If you are not running any kind of power, or do not have a swing kit installed, and the radio is stock, the meter in the radio is more then enough to get a correct SWR reading.
Posted on Apr 24, 2009
Why is the swing on my cobra 29 ltd with bt swinging backwards with i talk
because when you tried to modify the radio for more power and audio you turned the wrong coil and can.
Aug 01, 2012 | Cobra 29 LTD CB Radio
Main power was hooked up backwards, now unit won't power up. how much damage is likely?
i gus i hook up the power up and blow some thing it is a black 29 cobra got aney thing to fix it
Feb 06, 2011 | Cobra 29 LTD CB Radio
How to fix the dimmer light ona cobra 29 nw ltd classic
HI I AM TRYING TO FIX MY 29 COBRA LTD IT WENT OUT ON ME
Feb 04, 2011 | Cobra 29 LTD CB Radio
When I plug in power cable it pops fuse
This radio has been hooked up backwards you have to change the resistor in the radio if you keep changing the fuses and turning it on it will do more damage to the radio there is no easy fix you have to change out the part.
Aug 12, 2010 | Cobra 29 LTD CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
I have a Cobra 29 NW LTD Classic I have power going to radio but no power when i turn on knob. i have looked inside for a fuse but can not find one.
did you look for power comming out of your power switch....
dont tell me that you hooked it up backwards. if you did check the imput diodes
Aug 29, 2009 | Cobra 29 LTD CB Radio
I have a cobra 29 nw ltd classic i cannot hear or be heared
Start with the antenna that you have hooked to it, is it grounded, is the coax in good shape, is the connector in good shape. stuff like that.
Jun 14, 2009 | Cobra 29 LTD CB Radio
Modulation sounds bassy!!!
first change mic ,maybe the problem are in this mic ,second if the mic is ok verify all capacitors in the modulation near of this ic ,if all are ok change the modulation ic and change it, i hope this help you
Apr 12, 2009 | Cobra 29 LTD CB Radio
Cobra classic 29 ltd
Had fixed the same problem yesterday. My cobra worked when it wanted to, when it didn't it looked like you explained. I found out that on my cobra the blue wire on the mike connector was broken. When it disconnects, no sound. after soldering, everything works fine.
Dec 04, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
95 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
