Question about Electrolux ICON Designer E30SO75ESS Oven
Same problem, cleaning the oven for the first time and after removing the racks continue to get "Remove Racks" displayed preventing the cleaning cycle to begin. In my oven the side rack supports are one continuous piece through the top of the oven so I know they can't be removed as suggested. I also looked for that nipple piece in the back left corner but found nothing. The dealer suggested resetting the oven by shutting the circuit breaker off... didn't work. Waiting for service to come and fix it. Amazing that a company of this magnitude would have this same problem for 5 years.. Is anyone from Electrolux listening VOICE OF THE CUSTOMER appears to be a dead issue with this company...
  • Electrolux Master
  • 1,886 Answers
3 Suggested Answers
  • 523 Answers
SOURCE: Removed racks and rack support from my Electrolux
turn off power the back on
Posted on May 27, 2010
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
Message to remove racks when trying to self clean,yet all racks have already been removed.
This message is a reminder to make sure the rack are removed only. If they are removed then continue with the self clean cycle. Good Luck
Mar 22, 2016 | Electrolux 30" Built-In Single Electric...
On my model #EW30EW65GS3 in the self cleaning cycle even tho I removed all the racks & the rack supports it keeps flashing remove racks
Hello. From what you're describing, there might be a problem with the rack switch. It is connected directly to the main oven display board at connector P10 for a single oven(See pic 3, left side, middle). On the double oven model, there will be a P12 connector near the same area. TURN OFF POWER TO THE OVEN BEFORE ATTEMPTING TO CHECK ANYTHING!! On the double oven display board, there will be a connector P10 and P12 for the upper and lower oven racks.The part number for the main oven display board is 7316516536 in case the switches are good. The rack switch part number for the upper and lower oven is 7318903403. The part number is the same for the switch in the single oven model. Note the designation on the exploded parts diagram as 14(with a circle around the part). I've included the last pic(the oven relay board) just for future information.The part number for it is 7316443919(dual oven relay board). If you are hesitant about attempting to troubleshoot the oven, definitely call for service! This can be an INVOLVED REPAIR requiring advanced troubleshooting. The connectors on the circuit board can be damaged easily as they are multi-pin devices. You will need a voltage/ohm meter with fine probe tips to perform continuity checks on the rack switch(s). I hope I helped you!
Sep 26, 2015 | Ovens
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon range won't self clean - "Remove Racks" displayed
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux ICON Designer E30SO75ESS Oven
How can I clean the racks in my oven
I use oven cleaners like Easy-off to remove the mess. You usually have to spray the cleaner on the racks and oven, then heat it up to the temperature in the instructions. In 5 minutes or so, the cleaner dissolves tough oven grease and food spills will wipe away easily.
Check out this site:
http://www.easyoff.us/
There are printable coupons as well.
May 06, 2012 | Ovens
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
Need to clean, do I need to remove the racks prior to self-cleaning?
Yes. Always remove oven racks before self cleaning to prevent discoloration.
Jan 31, 2010 | Dacor MCS130SS Millennia Electric Single...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux ICON  Designer E30SO75ESS Oven Logo
70 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
