Question about Garden
Will only start by 2 or 3 drops of gas incarb
    Problem Solver:
  • 5 Answers
Sounds like you have trash or water in your fuel
Posted on Oct 22, 2013
Pressure washer was running and it back fired. now it won't start. has fresh gas,cleaned out bowl,float and needle. will start breifly with couple drops of gas in carb but won't stay runnin but 2 seconds.
CALL YOUR LOCAL PARTS STORE AND SEE IF THEY CARRY C-FOAM. IT IS A LIQUID THAT YOU POUR INTO THE CARB, LIKE YOU WOULD A LITTLE GAS TO GET IT STARTED. BUT THE C-FOAM WORKS MUCH BETTER AND WILL CLEAN OUT YOUR PROBLEM AND SHOULD GET YOU GOING. I HAVE UDES IT SEVERAL TIMES FOR VARIOUS PROBLEMS AND THIS STUFF IS WORTH EVERY PENNY. THEY MAKE 2 KINDS OF C-FOAM. READ THE DIRECTION TO BE SURE YOU ARE GETTING THE RIGHT ONE
Sep 01, 2013 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
2004 Dodge Durango Electronic Throttle Control Problem and Poor Fuel Economy
The first thing you need done is to have a Dodge dealer run the system for fault code.
Jul 02, 2012 | 2004 Dodge Durango
Rheem 90+ NG Furnace. When furnace starts, draft inducer starts, ignitor glows and gas ignites. Burners stay lit for 10 seconds or so, then the flame reduces for a few seconds then goes out. Main blower...
Check the draft inducer air switch ( vacuum diaphragm switch) If the switch is opening when the burner starts, you might have a blockage on air piping coming into the furnace. Also prime the condensate trap on the condensate drain from the combustion fan. Also check the gas pressure, if your gas pressure is dropping, the gas pressure switch will shut it down. If it's too high the moment it comes on could raise the pressure in the furnace dropping out the combustion fan proving switch.
Oct 29, 2010 | Electric Circuit Breaker Kit for Furnace
Craftsman Weedeater won't start
You are definitely on the right track. There is only one thing that could be wrong as long as you replaced the needle valve, screen, gasket, & diaphragm. When cleaning the carb., you need to clean the small portals incarb. with a Den Tek Brush, (used for cleaning between teeth), they work great for this job. These portals, if blocked slightly, can cause this problem.
Jim
Jun 01, 2009 | Craftsman 25cc Gas Line Trimmer
2000 Ford Expedition Starting problem
If the fuel gauge drops off when you are driving then its a sending unit problem that means you have to drop the tank and replace the float and sending unit. This is a common problem for alot of cars because of cheap gas. If you have to drop the tank check the fuel pump canster for dirt because of cheap gas. Replace the fuel pump strainer and fuel pump filter. If the car or truck has about 100,000 miles you might want to change the fuel pump at that time also just to cover your back. If you take it to a shop they will charge you at least $900 to start. But if you do it yourself it will cost you about $200 dollars maybe alittle more.
Mar 19, 2009 | 2000 Ford Expedition
Gmc truckturns over but won't start,fuelpump.
Hit the bottom of the fuel tank. This jars the fuel pump. If the truck starts You need a pump. Common problems to GM is the pump.
Mar 01, 2009 | 1998 GMC Sierra
1992 celica wont start after running out of gas
the fuel pump boot is full of debree off the bottom of the tank. two ways to fix the prob. 1 dont run it out of gas anymore, or 2 drop the fuel tank and clean it out
Feb 08, 2009 | 1992 Toyota Celica
Loosing power 1&2 start dies when apply gas
Hesitation can be caused by the spark dropping out. This could be related to a faulty distributor. Try installing an in-line spark tester (can buy at any auto parts store for a few bucks) and see if the spark drops out when you rev the motor up and it begins to hesitate. If so, it is likely the distributor has gone bad.
Dec 17, 2008 | 1994 Ford Aspire
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
