Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Have a samsung ref mn#rf195abrs water under the crispers. french door model
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
  • 363 Answers
SOURCE: inside of frig sweats so much water collecets
sounds like you need to clean all of the door seals and all contact points on the refrigerator. Do not use alcohol. use a damp rag
Posted on Jul 30, 2009
  • 146 Answers
SOURCE: kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Posted on Aug 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
oldTech2332
  • 2341 Answers
SOURCE: My refrigerator is leaking water
That sound as if the defrost drain is blocked. This tip i wrote will help ya get to and check/clean the drain http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Posted on Sep 05, 2011
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water in my crisper and bottom of the refrigerator
Sounds like the drain pipe at the back lower side of the fridge may be blocked pull out the crisper to locate and try putting some water in it and see if it drains away if not try clear it with a small hose .
Feb 24, 2014 | Samsung RF217ABBP Bottom Freezer French...
Vegetable crisper is filling with water
You may have have your freezer drain stopped up and when it goes into defrost, it melts and the water spills over to the lower section being the crisper. This is a simple fix. You just need to find out where the water is coming from .
Feb 05, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Why is water pooling under right crisper?
On defrost refrigerators water is drained down the sides to an outlet on the bottom of the interior of the unit and then to a tray under the unit, close to the floor, where it is heated and evaporates.
If he hole inside is plugged then the water will pool inside.
Take out both crispers and try to find the location where the water will flow out. It may be plugged with gunk The inside bottom of the unit may have indented runs where the water will be directed to the outlet.
Oct 27, 2011 | Samsung RF217ABWP (20 cu ft) Bottom...
I have a Samsung French door fridge that has a problem with ice building up inside the back wall of the firdge and water accumulating under the crisper drawers. We have been unpluggint he fridge...
Access is from the rear, but make sure the vents on the front grill are not clogged also because it does need front to rear air flow.
Your unit has two evaporator coils and two defrost heaters and two defrost thermostats, but uses one defrost timer circuit. So if you don't have trouble with the freezer side, then it should be the defrost heater or defrost thermostat for the refrigerator side of your unit. Which are items 1-2 and 1-4 on the following diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Refrigerator-Parts/Model-RF265AABPXAA/1482/0161000/50033424/00002
Aug 17, 2011 | Samsung RF265AA Bottom Freezer French Door...
Fridge is collecting water under the crisper drawer of my Samsung RF217 fridge, has french doors and bottom freezer. How do I get to the drain hose to thaw/flush it?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | Samsung Refrigerators
I have a model RF26VABPN french door, bottom freezer unit. It has a leak of cold water pooling under the crisper trays. I can't find where the leak is coming from. I clean the water up, and within days,...
Defrost drain plugged in fresh food section. Samsung will repair it under warranty. Might pay for it if you complain nicely, if it is out of warranty.
Mar 31, 2011 | Samsung Refrigerators
Freezing in left crisper drawer.
If you have had a DOE upgrade the fix is availiable from LG
Here is the service buliten # CREF20090877.
Contact LG @ 1 800 243-0000 for repair.
In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
