Question about Garden
HHomelite HED 1520 Curb Runner Edge trimmerer
Were in NZ could I buy a new cutter blade
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 2976 Answers
SOURCE: How do you replace a 9596 Fiskars paper trimmer blade carriage?
Take it to the middle and flex the slot open.
Posted on Aug 09, 2009
  • 10865 Answers
SOURCE: trimmer not cutting as well as it use to. Do I
hello. Both of your solutions will give you what you need which is a trimmer that cuts well. Here is the link to remington where you can price each choice. Joe http://www.remington-store.com/category.asp?CAT=parts
Posted on Mar 29, 2010
Testimonial: "thank you very much!"
bbap
  • 71 Answers
SOURCE: I have a 22inch Craftsman Hedge Trimmer, Model No.
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Posted on Sep 27, 2010
rycgl
  • 1545 Answers
SOURCE: I bought a homelite curb
I found that your electric edger blade is rounded on the ends. I did not find a part number for it. I also found a site that has about 30 or more Homelite edger blades listed, but again, with half of them without pictures, I can't give you the edger blade part number. But, if you have removed the blade and can measure all the dimensions of the blade, then you can match it up with one from this site.They have more blades than other sites I checked. It should not be too hard as each blade listed has the critical dimensions listed with it. I wish you good luck.
http://www.mowtownusa.com/42.html?m5:search[keyword]=Edger%20Blade;search[keywordSearchType]=and;search[matchWholeWords]=1;search[keywordFields]=string0:text2:text0:code;search[active]=yes;search[fuzzy_sku]=1
Posted on Jun 19, 2011
My Bosch AHS 48-16 Electric Hedge Cutter hit a bit of wire, now there's s clickingn noise when trying to start it. Any help appreciated
It could have possibly damaged the cutting edge of the blades and put a burr on them, meaning that as the blades reciprocate, the 'burr' is catching on the other blade.. Check the blades for damage and use a flat file to smooth off any burrs that could be catching. (Make sure it's unplugged before doing any work on the machine)
May 10, 2016 | Electric Garden
The tip of blade will not come together or close.
if it is a hedge trimmer as per the catagory, get a new cutter bar or get a new hedge trimmer
probably from blunt cutters that tried to cut too thick branches
if it is secateurs then do as ray suggests
Oct 02, 2015 | Garden
Can I replace just the blade on my pizza cutter? It seems a shame to buy a new one as it really is in good condition, just the blade is blunt.
The Web Restaurant Store sells pizza cutter blades for a good price, although as the pizza cutters themselves are not expensive, you might find it just easier to buy a new one.
http://www.webstaurantstore.com/american-metalcraft-pcw-4-4-pizza-cutter-replacement-blade/69332864.html
Feb 28, 2013 | Home
I bought a homelite curb runner and need to replace the blade. The problem is I cannot find the blades anywhere. Any ideas?
Jun 19, 2011 | Garden
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
May 04, 2017 | Remington Precision HC-8017 Hair Trimmer
Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Aug 27, 2008 | Ryobi 18V Hedge Trimmer
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
