Question about Wfco WF68100 WF-68100 100 Amp Deckmount Power Converter Charger Camper
Need 101 help with my WFCO converter//charger Please! I installed a new refrigerator in the toy hauler. Have WFCO 68100 100 amp converter charger with 2-12 volt batteries. The converter seems to have dropped a leg of the power and now it is not showing that it is getting power at all with full hook up. I have tried to swap to 6 volts but this did no good. And everything works fine with the batteries being charged with a charger. Don't know what else to try before I order a new converter but want to make sure I don't lose that one too.
  • 438 Answers
12 volts to 6 wow not a good thing to do my friend, check your converters power out put bye connecting a load to it,IE headlight or other load if it no light it no workey check for power to the unit AC check for fuses open if not replace the converter, all is OK if you did not get smoke when you connected a fresh set of battery's to your unit toy hauler distribution system.
best regards Falco
Posted on Nov 05, 2013
How can I Troubleshoot wfco 8955 power converter on my 2006 Rockwood travel trailer?
If you have input voltage 110 volts. On the white and black wires. No output voltage at the red and white wires. It's garbage there's nothing serviceable on the unit.
Oct 16, 2015 | RVs
Problems with wfco wf8735p
Look in the box and check the 40amp fuses to see that they are not blown.Make sure there is no power before you do this.Also disconnect the battery,just as extra precaution .
Jun 22, 2014 | Wfco WF8735P WF-8735-P Brown 35 Amp RV...
What are the problems with the wfco wf8735p
Disconnect power and check the large fuses in the wfco.
Slow rate of charge
Have your battery checked with a hygrometer to test the condition of the electrolyte (if possible). If its a premium battery (not lead acid), and more than 3-5 years old, it may need replacement.
Dec 08, 2013 | Wfco 8955 WF-8955PEC WF-8955AN 55 amp...
Hello all, I just bought a Little tiles haul and ride (612442). While assembling, the part F was latched on to part B (by mistake) before I could put in the parts D and E. So I now basically have part B...
What I know of Little Tikes is that they are snapped on to complete the a toy. They don't make any permanent attachments to easily assemble and disassemble them. If you're having a hart time removing that part, I suggest you bring it back to the toy store where you bought it and maybe they have a personnel there who can help you.
Oct 07, 2013 | Little Tikes Handle Haulers Haul and Ride
Fan on converter starts then stops right away and wont charge battery
Disconnect all power and check the large fuses to see if they are not blown.
Aug 28, 2013 | Wfco 9855 WF9855 WF-9855 55 amp deck mount...
Onan generator 2005 model hgjab-1038c rv generator will not keep batterys charged have to hook battery charger every time that generator is not running what should i check for this genator is in my 2005...
Go to the auto parts store and buy a "Battery Tender" solar powered, or get an electric trickle charger. Or install a battery disconnect for the period the unit is not in use; you can disconnect the battery.
HTH,
Mike...
Dec 02, 2009 | Watts Onan Portable Generator - 5000 ,...
I had to replace the WFCO power converter, as it had gone bad. The refrigerator would not work either, with the check light staying on all the time, even with a good battery and no AC powere connected. Now...
RVIA
Recreatio Vehicle Industry Assocition
http://www.rvpartwholesaler.com
Dometic 9108677537 A&E Carefree RV Awning Pull Strap
Dometic 3307834.006 A&E Carefree Window Awning Pull Strap 28"
WFCO 8955 55 amp converter. New w/ warranty! US Seller.
WFCO 9855 55 amp deck mount converter. New w/ warranty!
Aug 06, 2009 | Dometic RM2652 Refrigerator
Wfco WF68100 WF-68100 100 Amp Deckmount Power Converter Charger Camper Logo
189 people viewed this question
Top Wfco Electronics - Others Experts
Are you a Wfco Electronics - Other Expert? Answer questions, earn points and help others
