Question about Nokia Computers & Internet
Micromax x333 pda ok but not working - Nokia Computers & Internet
Can not get the device to turn on
There should be a pin hole on the back of the PDA. Press the hole using a thin paper click. This will RESET your PDA. Press the power button and it will work OK. All PDA's have a RESET option.
Jun 01, 2015 | Palm z22 32mb handheld pda organizer z22-b
No incomming call
Check if you have activated any diverts. If possible, put the sim in other handset to see if the problem persists. If nothing works, try resetting your phone or take it to the service center.
Nov 10, 2011 | Micromax X265 Cellular Phone
How to repair micromax x114 sim tray not working Problem
my micromax model x114 no disply solution plese
Aug 23, 2011 | Cell Phones
Micromax q7 phone security code Problem
i forgot my phone code micromax q7 ho15 m-IMEI:910058102117972m -IMEI:910058102117980 sn:ti8aq7o3100105900 H/Wver:tbg2o49-p4-001 S/wver:204910-6890-v2679
Jan 23, 2011 | Cell Phones
What is the default password for micromax x260
I am not a Micromax expert but let me share you what I know of. The default Micromax Security Codes are 1122, 0000, 000000 and 1212. On most micromax models, 1122 works. Hope this helps.
Good Luck.
Thanks for using FixYa.
Jan 10, 2011 | Intel Computers & Internet
Nimbuzz is not working on my micromax q55
Nimbuzz not working at Micromax Q55
Oct 21, 2010 | Cell Phones
Setting on internet in micromax q3
following are the steps to use internet on ur micromax Q3 handset:
Step 1. : Open the Menu nad then go to services option.
Step 2. :Click on that and move to Data account and then Click ok.
Step 3. :Select the GPRS & then click OK.
Step 4. :Go to the empty account and then click on Edit.
Step 5. :Write 'PI' (means Pockit Internet) on the Account Name.
Step 6. :Write APN = aircelgprs and leave the username and Password as blank. Auth. type will be Normal.
Step 7. :Press Back Button three times, u will be on the services menu.
Step 8. :click on the WAP and select the sim number u want to access the internet and press OK.
Step 9. :now u can access the internet.
Hope this is helpfull
Mel
Jun 08, 2010 | Opera Software Browser
Wi-fi PDA connectivity problem
First, restart your pda by using your stylus and pressing the pin-hole sized button on the back of the PDA. There are sometimes a couple of different reasons why the pda wont recognize the network. Main Reason: Make sure you are at the home screen... Tap the wifi icon on the lower right corner of the pda. T hen make sure that the WLAN power is turned ON. Press the setting button. If you see your network in the list, tap on it. It should bring up a network configuration window. Make sure it says it connect to "The Internet". Then tap on the "Network Key" tab at the bottom of window. If you have no security settings on your belkin router, make sure Authentication is set to Open and Data Encryption is set to "Disabled". Then press "OK". That should Be it!!!! Let me know if this way doesnt work, or if something doesnt make sence!
Sep 15, 2005 | Dell Axim X50v Pocket PC
E750 use with Garmin 76 GPS
If no one has any solution for your issue in my opinion you should check the manufacturer’s site. Maybe there you can find out if this unit is compatible with your PDA. Usually you can find it under support or FAQs.
Sep 08, 2005 | Toshiba e750 Pocket PC
Computers & Internet Logo
26 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
