Question about Lasko 3300 Wind Machine Fan
What wire color matches the number on the switch?
Need color code and number for wiring 96 dyna
Hi Anonymous, for a free wiring diagram please visit website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 07, 2014 | 2002 Harley Davidson FXDWG Dyna Wide Glide
How to replace a 3 speed pull chain
Open following link for illustration and instructions:
As a general rule, the new 3-speed switch has to have same number of wires (either 3 or 4).
The new switch and old switch have to match electrically, which means the old and new switches have to be tested with a continuity tester or multimeter (both testers available at local hardware).
Testing is necessary because wire colors do not always match and because each pull chain can activate different wire or combination of wires.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Add a comment for more assistance as you work on the project.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on 3-speed switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Gardner Bender Gsw-34 3 Speed Pull Chain...
Changing switch box to universal remote but the number of wires don't match switch out hunter model 85464 switch box for hunter universal remote model 27227 060 but the number of wires done match and odd...
Hi. Your best bet here it to call Hunter directly as they have people on hand with all of the schematics who will assist you.
888-830-1326
Monday – Friday 7am – 7pm CST
Saturday 8am – 5pm CST
J.
Jul 22, 2010 | Hunter 52" Ceiling Fan With Light And...
Replacing car radio (JBL) with a Pioneer (DVD) Toyota Sequoia
I have used what is called a toyota car harness to iso adapter for this sort of thing .
aerpro APP0141 check at your local auto shop
https://automotivesuperstore.com.au/aerpro-app0141?gclid=Cj0KCQiAtJbTBRDkARIsAIA0a5MqtkIR92nbYhY-M6qqHBjfuaEZVlBE7lJuD_VMtvlU3MCtIRUgNpEaAnfREALw_wcB
it converts your toyota to a international standard ISO and then you buy a Pioneer {whatever model number } to ISO and then you can plug them together and get the radio and car talking to one another.
Jan 22, 2018 | Pioneer Car Audio & Video
I have a 1989 sea ray boat. Does it have no power to the coil?
If you look at the coil you will see small wires on either side. One side is a ground and the other is power. Depending on the brand of outdrive you have the wires are color coded.
You should be able to see the color of the wires on the "Plus" side at the coil. Then follow the wiring loom back to the switches hanging by the shift cables on the engine. There are also wires on the UP/DOWN safety switches of the outdrive.
The outdrive must be down somewhat for the safety switches to release the ignition LOCKOUT. This is done because the driveshaft will snap if you start the motor with the outdrive up. Look for matching color coded wires to match the small hot coil wires.
The switches on the shift cables will LOCKOUT the starter solenoid so you can only START in neutral. Look for the color coded wires from the coil to see if they are on the correct set of switches. It is possible someone made a redundant connection and combined the ignition with the starter cutoff.
May 01, 2010 | Boating
Can't match color wires to thermostat codes. I'm replacing my thermostat and I have 6 wires coming out of the wall but can't match colors to proper connections on thermostat. I have an electric heat pump.
Make sure you have a heat pump thermostat. Standard stat wire and stat wiring are as follows.
  • R to red
  • W to white
  • Y to yellow
  • G to green
  • O/B to orange
  • C to blue or W2 to blue
Your wire colors and stat brand and model number would be more helpful if this does not clarify. Repost with additional information and I would be glad to help further.
Oct 06, 2009 | Heating & Cooling
Match color coded wires
Ask the person who sold you the sensor. They should have the info. Ebay sellers frequently post connection info on their web sites.
Sep 26, 2009 | 2004 Saturn ION
OK I HAD A BAD LID SWITCH ON MY KENMORE WASHER SO I BOUGHT ONE THAT LOOKED EXACTLY LIKE MINE. WHEN I GOT HOMWE I FOUND OUT THE PLUG IN WAS DIFFERENT. IT HAS THE SAME THREE WIRES ALL MATCHING COLORS. SINCE...
Look at both switches for markings by the contacts or wires or on the switch itself.
NC = Normally Closed connection
NO = Normally Open connection
C = Common connection
If the colors match the markings on the switch you should be good. If they do not match wire colors, match the markings NC – NO – C marked on the switch. Also make sure the voltage and current ratings are the same or higher than the original switch.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Lasko 3300 Wind Machine Fan Logo
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
