Shut the heater gas off, cleaned all the dust and dirt from it, relit the pilot, thermostat clicks like it wants to start, no heat
  • 2,113 Answers
From hanging around this site i've read that the thermocouple needs a sanding to generate enough power to give feedback that the flame is working ok
Posted on Oct 22, 2013
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Pilot light lit but no heat
the pilot's millivolt generator may be at fault.  if you have a meter that is capable of measuring a very small DC voltage, connect it up to the very end of the thermocouple and the copper cappillary. the thermocouple has a welded bead at the very end inside that generates a small DC voltage. Same principle of a J-K thermocouple. Iron constintan  - two dissimiller metals where joined together produce a voltage when heated.  the thermocouple actuates a millivolt electromagnet inside the valve to keep the valve pellet open.  no voltage there it won't actuate the electromagnet.
Posted on Oct 15, 2007
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
SOURCE: pro comm natural gas heater, pilot keeps going out
The problem is likely to be either the thermal-couple (easily replaced) or a clogged gas orrifice. The clogged orrifice would require a bit more know-how then the thermal-couple and with gas appliances it would be best to hire someone who knows what they are doing.
Posted on Mar 21, 2009
Y does my glw-warm heater keep shutting off
Is this an unvented heater? They have oxygen depletion sensors which shut off the heater to prevent burning up all the oxygen in the room. Heaters over 10,000 btu's should not be used in small rooms like bedrooms and bathrooms. Other causes could be a dirty pilot orifice. Turn off the unit (so pilot is off) and use a can of compressed air with attached straw, to blow out any dust from the pilot assembly. (Where the pilot flame comes out). This will allow the pilot to burn a strong blue color and keep the thermocouple heated properly. If it's a thermostatically controlled heater, make sure your thermostat bulb is cleaned off regularly. Dust will insulate the bulb from sensing the room temp and will not operate properly. Hope this helps.
Mar 25, 2015 | Heating & Cooling
My Kozy World nat gas wall heater has worked beautifully for the past three winters. I cleaned it this morning with canned air, got all the dust off the ceramic plates, blew out the burner inlets, blew out...
Does the pilot light stay lit if you continually depress the control valve?
If the pilot light stays lit as long as you keep the valve depressed, then the problem is the thermocouple is bad. The pilot light makes enough electricity via the thermocouple to hold open the gas valve that feeds the burners. If the thermocouple fails to produce that electricity, the gas valve will shut down and switch off the gas flow to the whole unit.
Mar 05, 2015 | World Heating & Cooling
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
WATER HEATER GOES OUT OVER NIGHT
you either have a back draft blowing out the pilot light, or a bad thermal coupling. if coupling is bad it will shut down the gas flow therefore shutting off pilot light. its a safety measure to stop the gas flow if pilot goes out. replace thermal coupling, that may do it. good-day ! but shut off gas first !
Mar 21, 2012 | Water Heaters
I have a reliance power vent heater model 8 40 navto . When the water temp called for the heater to work the solenoid started clicking and when it stopped the pilot flame was out and cannot be relit. The...
First suspect is always to clean combustion parts.
I don't have that specific manual, but assume unit has digital gas control valve thermostat.
http://www.reliancewaterheaters.com/lit/om.html
As a general rule, the gas control thermostat activates the blower and turns on the gas, and controls flow of gas to pilot.
If the ECO is tripped, or there was FV event, or the gas valve thermostat is bad, or the combustion parts and tubes need maintenance and cleaning, then the pilot will not relight.
Open following link for older Reliance troubleshoot manual, plus some troubleshooting resources and illustrations:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Add a comment and say what you did to restore functionality.
Jun 13, 2011 | Reliance Natural Gas Water Heater Control
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
I have a coleman evcon and the gas keeps shutting off
The click noise you hear is the magnet inside the valve dropping out. Which means, the voltage that energizes it is low or interupted. Possible, weak pilot flame, bad thermocouple or bad secondary limit switch. This limit switch is located left of the main control. made of ceramic. It can also be a bad gas valve...
Mar 23, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
