Error e010 on Canon ir325s copier - Office Equipment & Supplies
  • 3 Answers
Check whether there is paper jam
Posted on Dec 23, 2013
Cogz
  • 1326 Answers
SOURCE: iam getting error code E010,E014
A E010 & E014 have to do with the main motor drive. You may have a drum blade that has flipped or it could be that the center screw that locks the drum to the drum shaft is loose ( just tighting screw- you can also get blank copies as well. The E014 deals with the fixing unit, you have to make sure it is spinnig freely. It could be that the lower pick off claws have dug in to the lower fixing roller, or the ball bears are siezed or the web is rapped around the upper fixing roller or a bushing is broken or it may be to much pressure is on the UFR from the web... Just a few ideas.. Good Luck
Posted on Nov 07, 2008
SOURCE: Canon NP 6030 Error code E010
chiudere sportello superiore destro
Posted on Oct 16, 2009
brett207
  • 231 Answers
SOURCE: problem for canon clc 1180 copier E010
Main Motor is jammed on something, or the motor controller PCB is faulty.
Check for blockages inside the machine.
Probably will need a service technician to fix this
Posted on Dec 08, 2009
tonesmaker
  • 60 Answers
SOURCE: What does error code e010 indicate on the Toshiba
open the side door >> you find any paper?? remove it
else you need to change the jamming sensor
Posted on May 13, 2011
manzoorpudus
  • 13 Answers
SOURCE: error code e010 in Canon GP 225
Main Mottor
Posted on Feb 29, 2012
Canon ir 2018n error code e010
check the drive of the main motor >may be a broken gear .If that is ok then check the main motor in another machine.If that is also okie then u have got urself a fried DC controller PCB.Replace it
Mar 28, 2012 | Canon Office Equipment & Supplies
How to fix error E010 fo canon ir1600
I am getting the Error "E010 Locked" can you help me how to unlock.
Feb 27, 2012 | Office Equipment & Supplies
I have canon np 6650 it shown E010. i have try to reset, checking the fuse on the dryer paper please help me
if error E010 occure, it means your Main motor not running,
motor or motor drive board or mother board problem,
if show E010 after running the main motor, check motor driver board or mother board,
but 99.9% case of E010, cause of main motor problem so check the main motor first,
Aug 11, 2011 | Canon NP 6650II Copier
Error E010
"E010" Drive problem
http://www.manualshark.org/m/canon-np6150-6650-6650ii-7050-7550-8070-8530-8570-8580-black-994/
http://eshop-manuals.com/index.php/cPath/4
Above is a service manual a MUST HAVE in order to fix, above that is a user manual, for troubleshooting.
Apr 28, 2010 | Canon NP 6650II Copier
User manual or User Guide of iR325s and iR5000/6000
give me your email and ill try to get some manual for you
Mar 11, 2010 | Canon imageRUNNER 5000 Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
Oct 04, 2007 | Office Equipment & Supplies
Canon ir 8500
E010 relates to a main motor fault. A specified amount of rotations has not occurred within a set time. Check motor, see if it turns by hand. If not, inspect and/or replace. Check belts and gears for wear/damage, replace as necessary. E065 relates to a primary charging problem. Suspect primary corona arcing, corona wire broken, High-Voltage PSU may be unservicable, black developer unit may be pulling HVT down. How many copies has each machine done? Recommend calling an engineer, parts are probably required.
Sep 09, 2007 | Canon imageRUNNER 400S Copier
35 people viewed this question
k24674
