Question about Garden
Torque settings for bolts mitsubishi 4dr5 flywheel
  • 375 Answers
SOURCE: Flywheel bolts torque settings
Check with your local auto parts store. Or buy a repair manual
Posted on Jul 01, 2008
SOURCE: Torque spec for flywheel bolt: Isuzu 2.5 diesel engine
normally 110 nueton metres. use nut lock and once you have torqued you will feel if you have to tighten it a bit more.
Posted on Aug 15, 2008
joecoolvette
  • 5660 Answers
SOURCE: Bolt torque specs for flywheel, pressure plate,
1.Flywheel - 61 to 69 Foot Pounds
2.Pressure Plate - 25 to 33 Foot Pounds
3.Bell Housing - No specs found. I would say 25 to 35 foot pounds should be sufficient.
Bolts clean on ->flywheel to crank, ->pressure plate to flywheel, and ->bell housing to back of engine, I would use TWO drops of Loctite Red threadlocker, on ALL of these bolts.
Hope you have an alignment tool for your clutch disk when you install it. Auto parts stores sell the plastic one's cheap! Saves a LOT of headaches!
Tighten the pressure plate EVENLY! Snug the bolts down until they just TOUCH, then go in a criss-cross pattern when tightening. Do the tightening in incremental stages! You turn one bolt one thread, you go across to the opposite side, and turn that bolt one thread. Keep criss-crossing so the pressure plate goes down EVENLY. (YES, it's a pain in the keister!)
If NOT, you'll have a warped pressure plate, and it will be junk!
Thanks for letting me say that, I feel better.
Posted on Jul 07, 2009
morse008
  • 1111 Answers
SOURCE: I need torque settings for 1600 beetle engine SP
wiki this
Posted on Aug 25, 2009
  • 1796 Answers
SOURCE: mitsubishi canter truck 4d34 torque settings
Hi!!!
Most manuals I found do not cover diesel engines. There is a Peter Russek manual for your truck which covers diesel engines. Click on the following link to check the manual http://www.auto-repair-manuals.com/Mitsubishi-1997-2002-L200-2WD-4WD-2-0L_2-4L-Petrol-2-5L-Diesel-Russek-Repair-Manual.html
THIS ARE THE SPECS FOR A 04 MITSUBISHI LANCER. Identifying Fastener Tightening Specifications Table ITEMS SPECIFICATIONS Roll stopper bracket mounting bolt69 ± 10 N.m (51 ± 7 ft-lb) Shift cable bracket mounting bolt19 ± 3 N.m (14 ± 2 ft-lb) Select lever mounting bolt19 ± 3 N.m (14 ± 2 ft-lb) Speedometer gear mounting bolt4.0 ± 1.0 N.m (35 ± 9 in-lb) Backup light switch32 ± 2 N.m (24 ± 1 ft-lb) Interlock plate bolt30 ± 3 N.m (22 ± 2 ft-lb) Poppet spring32 ± 2 N.m (24 ± 1 ft-lb) Control housing mounting bolt19 ± 3 N.m (14 ± 2 ft-lb) Under cover mounting bolt7.0 ± 1.0 N.m (61 ± 9 in-lb) Reverse idler gear shaft mounting bolt48 ± 6 N.m (35 ± 4 ft-lb) Clutch housing-transaxle case mounting bolt44 ± 5 N.m (33 ± 4 ft-lb) Front bearing retainer mounting bolt19 ± 3 N.m (14 ± 2 ft-lb) Select lever mounting nut12 ± 1 N.m (104 ± 9 in-lb) Stopper bracket mounting bolt22.3 ± 0.3 N.m (16.1 ± 0.2 ft-lb) Clutch release bearing retainer mounting bolt9.8 ± 2 N.m (87 ± 17 in-lb) Differential drive gear mounting bolt132 ± 5 N.m (98 ± 4 ft-lb)
Posted on Sep 30, 2010
Torque settings on a yaris 1.3 16v big ends,mains,flywheel,cylinderhead
Toyota Yaris Main and Big end Torque settings:
Tighten the main and big end bolts in sequential order and in two steps.
Main bearings. Stage 1.
22 ft lbs.
Stage 2.
44 ft lbs
Big end bearings.
Stage 1.
11 ft lbs.
Then Rotate bolt head a further by 90 degrees
Head bolt torque must be done in 3 steps:
1st 22 ft lbs
2nd 43 ft lbs
final 47 ft lbs
use this sequence of tightening:
9 - 3 -1 -6 -8
7 - 5 - 2 -4 - 10
Flywheel spec:
65 ft lbs
Jul 15, 2016 | 2007 Toyota Yaris
What is the torque setting for nissan navara v6 4lt2007 flywheel torque
there are 2 sets of torque specs for flywheel bolts as there are 2 different fly wheels in use with different bolts for each
go google and type in--torque specifications for nissan navara flywheel bolts and fins a site relevant to you application
it could be 61-69 ft/lbs a or 90 ft lbs depending on the flywheel and the vehicle 2wd or 4wd
Sep 30, 2015 | Nissan Cars & Trucks
Engine torque settings mitsubishi 4d32
im looking for information by a 4d32 Mitsubishi , help!!!!!! thanks
Apr 03, 2012 | 1988 Mitsubishi Cargo
How to install a clutch kit on my 1994 mitsubishi mighty max
Disconnect the battery, disconnect the Hydraulic Line from the Slave Cylinder, Remove the Starter (2 bolts, 2 wires. Bolts are 14mm, 1 wire is 12mm, 1 plugs in), Remove the Driveshaft(s) (4 12mm bolts) Remove the 6 bolts from the bellhousing (4 are 14mm, 2 are 10mm)
Remove the bolt from the Transfer Case Mount, 12mm (only if it's a 4WD, if it's 2WD this doesn't apply), remove the 2 bolts that hold the Transmission Mount to the Crossmember (12mm or 14mm, it varies)
Slide the transmission back on the crossmember, away from the engine, I recommend running a ratchet strap across the frame to balance the transmission.
Remove the Pressure Plate from the Flywheel (Six 10mm bolts), Inspect the Pilot Bearing (if it needs replaced, you'll need to remove the Flywheel which is held on with six 18mm bolts, drive out the old bearing and drive in the new one, reinstall the flywheel, using Threadlocker on the bolts, torque the bolts to 100 ft lbs) Install the new clutch disc and Pressure Plate, with the centering tool inserted through the disc into the pilot bearing. Use thread locker on the pressure plate bolts and torque them to 20 ft lbs. Remove the centering/alignment tool after you've bolted it together
Remove old Throw Out bearing from input shaft on the transmission and slide the new one on. Slide the Transmission forward (make sure the input shaft slides into the pilot bearing, don't force the transmission into place or you could damage the clutch disc or break the input shaft) Torque the Bellhousing Bolts to 40 ft lbs (4 14mm bolts), Torque the 2 10mm bolts to 14 ft lbs, Install the Starter (torque bolts to 23 ft lbs), Reconnect Hydraulic Line to Slave Cylinder. Torque Transmission Mount Bolts to 30 ft lbs.
Reinstall Driveshafts, torque bolts on flange/yoke to 40 ft lbs. Fill Clutch Master Cylinder with DOT-3 Brake & Clutch Fluid, Open Bleeder Screw on Slave Cylinder and bleed the air out of the system, close bleeder screw.
Reconnect the wires to the Starter, Reconnect the battery.
Aug 24, 2011 | Mitsubishi Mighty Max Cars & Trucks
Mitsuibishi pajero 4m40 engine measuement of torque setting
Cylinder head (renew bolts)
stage 1 50nm
stage 2 100nm
stage 3 slacken of 360"
stage 4 tightn 50nm
stage 5 90"
stage 6 90"
stage 7 tighten the M8 bolts (the smaller ones) 24nm
Main bearings
20nm
90"
90"
Big end bearings
50nm
90"-100"
flywheel 125nm-135nm
Feb 10, 2011 | Mitsubishi Montero Cars & Trucks
Torque settings for 2005 lancer es fly wheel gearbox etc
2.0L Evolution engine
flywheel bolts 132 =/- 5 N.m. 98 +/- 3 ft lbs.
transmission to engine bolts 48 +/- 6 N.m. 36 +/- 4 ft lbs.
2.0L Non- Evolution engine
flywheel bolts 98 +/-5 N.m. 72 +/- 3 ft lbs.
2.4L Ralliart engine
flywheel bolts 132 +/- 5 N.m. 98 +/- 3 ft lbs.
Dec 28, 2010 | 2005 Mitsubishi Lancer
Flywheel torque setting vw transporter t30
VW Transporter 2.5 TDI-PD, (made year: 2003 ... 2007), engine code: AXD, 130 HP / 3500 rpm.
Important note: use new bolts!
Flywheel/driveplate torque setting: 60 Nm + 90 degrees.
Clutch to flywheel torque setting: 22 Nm.
May 21, 2010 | 2004 Volkswagen Eurovan
Bolt torque settings for fixing flywheel and torque convertor into GM700r4 gearbox. cheers
flywheel bolts m8 torque to 65-70 ft lbs in america so take that and do a convert eh and torque convertor bolts chek too 20 no more!!
Jan 15, 2010 | 1984 Chevrolet Chevy
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
