Question about Plantronics CS60 Professional Headset
Pair LG-MS770 up with a plantronics pro HD - Plantronics CS60 Professional Headset
  • 34 Answers
SOURCE: Pairing LG Shne cu720 to Plantronics Explorer 220
Try holding down the button on head set untill the phone reconizes
Posted on Jan 03, 2009
SOURCE: Plantronics Voyager 520 &having trouble pairing it w/LG VX5400?
i am having a problem getting my explorer 230 to conect with my phone can any one help?
Posted on Mar 02, 2009
  • 239 Answers
SOURCE: bluetooth code Plantronics 330 to LG AX300
try these codes
1234
4321
9876
6789
9999
0000
one of them will work
best of luck
please remember to rate me.
Posted on Mar 06, 2009
zohail
  • 1223 Answers
SOURCE: Can not pair Plantronics Explorer 220 on my LG enV2 phone
u have to follow certain guidelines to pair the device to your cell phone
first switch on bluetooth on ur cell then while your headset is switch off press centre button for long duration like 6 to 8 sec u will see that the blue light will be stable and continous then try to find ur headset in ur cell phone when u find it kindly select it and try to connect and if it ask for code type in 0000 four zeros and then it will pair up with ur headset you will see that blue light on headset will blink and then u can try calling
pls let me know if you have problems in the procedure i can provide more exact guidelines
pls rate me well !
Posted on Aug 27, 2009
fosg2000
  • 229 Answers
SOURCE: I can't pair up my plantronics Explorer 390 to my
For most Plantronics products, this passkey is 0000
please Rate me +++++
Posted on Sep 02, 2010
Cant get my voyager 510to connect to my nokia c2-01 mobile phone can you help??
Because this is a discontinued model going with a very new phone. I hope it works for you. Otherwise you may have to purchase a new headset. However when they discontinued that they did not make a replacement. You may want to look at the Voyager Pro HD.
Plantronics Voyager 510 Pairing Instructions
Plantronics Voyager Pro HD
Good luck from Headsets Direct!
Sep 29, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I am geting really bad staic in my plantronics voyager pro. I have the HTC EVO. Is there any way to get rid of the static?
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cant set to my phone
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cutting in and out. best described as sounds like i am talking into a fan.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
Need to pair new plantronics bluetooth to sanyo
Dec 10, 2009 | Plantronics Voyager PRO Bluetooth Headset
Plantronics CS60 Professional Headset Logo
16 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
