Question about Little Giant Plumbing
Wiring diagram Is a wiring diagram available for Little Giant Sewer Pump (model #509204)?
  • 3,368 Answers
The manual can be found at: http://www.gemplers.com/docs/manual/192177MANUAL.pdf
It has a simplistic wireing diagram, hope thatg helps.
Posted on Jun 17, 2014
  • 19 Answers
SOURCE: 10 Cia, 1/2 Hp, 83 Gpm Automatic Submersible Sump Pump 10' Power Cord : my little giant punp 10-cia has water in the main ...
Nope, not a good thing
Posted on May 18, 2010
  • 19 Answers
SOURCE: hello, my little giant dinosaur pump stopped
No reset, the pump may have just failed internally, try another plugin to varify power, if no joy than look at a new pump
  • 560 Answers
SOURCE: Little Giant pump WGP-90-PW trips GFI circuit
You might have 2 problems. The GFIC might be wired wrong or the pump wirng might be compromised with moisture. The noise issue? Are you running this unit without submersing it? They will burn out if you do. To get a more accurate running sound, submerse it with a flexible pipe so you can run it in a 5 gal bucket without losing the water.
It's possible a bearing is burned out.
Ron
Posted on Jul 06, 2010
hunter19_46m
  • 7482 Answers
SOURCE: I have a visible wiring
Hi acaffey7701...
You can repair it if you want to.
It can be done by skinning back the wires, cutting the wires,(give yourself a few inches of wire )slipping over the wires some heat shrink tubing the correct size for the wire, then sliding it out of the way, solder the wires back together, put the heat shrink tubing back over the bare wires and heat with a heat gun till it shrink fits around the wires. Then take black plastic electrical tape and tape the wires back together till it is almost the same size as the uncut electrical cord. After you have the wrapping of the tape done then you will get a tube of silicone sealant and put some of the sealant on the taped surface you just finished taping. Spread the silicone sealant with your finger and put it on the taped wire heavy.Let it dry and your good to go.
Or Replace the unit.
Please take time to rate me
Posted on Aug 31, 2011
SOURCE: Little Giant Condensate VCMA-15UL pump. Pumping when the float was down.
new pump
Posted on Nov 12, 2012
Who makes the motors for little giant pumps 3-MDQX-SC
Try taking it to a Grainger's store or go online to Graingers.com. There are usually enough numbers on the motor to find a match if there is one available.
Oct 21, 2014 | Little Giant 581507 3-MDQX-SC Magnetic...
Littlle giant pump model 2e-ndvr what oil goes inside this pump
"pump oil" usually is a fire redardant mineral type , ive seen good uses of dietary mineral oil avail at local phamacy , but is sort of pricey if filling a total pump up with it (allways allow for heat expansion)
Apr 01, 2013 | Little Giant 5-MSP Water Wizard...
553670 PUMP PARTS
Little Giant was acquired by Franklin Electric.
Your model number does not come up on their site so you may have to contact them directly.http://www.franklin-electric.com
Depending on what you need, you may be able to substitute from another source. Bearings and seals and bushings are readily available from many sources if you have the diameters and widths and seal requirements. Good luck.
Sep 28, 2012 | Little Giant PCR-10 230 Volt Peristaltic...
How to replace power cord on little giant pump
You have to buy a new cable ,remove the cover plate ,mark the wires before removal. (Colour) etc.Peel back the new wires and fit them exactly the same way as they came off,or get a professional to do the job.
Feb 14, 2012 | Little Giant Submersible Fountain Pump
My little giant water pump model 4mdsc has three
Sounds like you may have a 220V pump. So you need to confirm that this is a 110V pump and not a 220V pump. There should be a label or more info on line with any other info on the label. If you can confirm that this is a 110V pump, then put a standard plug on the cord - the green is ground and the other two can be wired to either blade of the plug. If you do have a 220V pump and you connect it to 110V anyway, the pump will perform poorly and will probably overheat and fail.
Jun 25, 2010 | Little Giant SPS25 Water Removal System...
Ron
Jun 10, 2010 | Little Giant Plumbing
Active Pump Will not shut off.
shutoff float/switch is stuck.. replace the pump.
Nov 07, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Plumbing Logo
268 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
