Goodman Model GPG13240451A, AC/Furnance - Will not start. I can hear the unit making a humming sound , but willnot start the heater blower/fan. What could be the probem. Can I reset the system?
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 25 Answers
SOURCE: blowing hot air fan not turning outside making a humming noise
Replace the run capacitor. It is a silver cylindrical object located in the electical compartment of you outside unit. There is most likely three places on the top where different color wires are attached. One is marked F,or Fan. The center should be marked C, or Common, and the last should be marked Herm, with wiring to the compressor. Make sure you write down or label each wire you remove and it's correct location. They must be installed on the new part just like they were on the defective part. For you to know which dual run capacitor you need, the old one will have printed on the side either 370, or 440 v,as in volts. You must also need to know the microfarad rating and it is also printed on the side with the voltage rating. Since this is most likely a dual(runs fan and compressor) you should see two ratings abbreviated as mfd. Something like a 5mfd for the fan motor and perhaps a 35 mfd for the compressor. CAUTION !!! This device has line voltage and you must insure the power is off at the disconnect/ breaker BEFORE you begin the repair. Sounds complicated but really only takes a few minutes. The main thing is getting the right mfd and voltage ratings for the new part and keeping a record of where the wires were mounted on the old one, and putting them back the same place on the new part.
Posted on Jun 18, 2009
FunnyPlumber
  • 43 Answers
SOURCE: fan won't turn on outside unit but has a hum noise
Be sure you have power, 220VAC to unit. You may have blown fises or tripped circuit breaker.
Posted on Jun 23, 2009
james3751
  • 614 Answers
SOURCE: I have an outside unit mfr Goodman, model #
You have bad capacitor on your unit it may not look bad but chances are it is just get the microfarad rateing of the side of the cap. should be like 55.5 55 7.5 something like that. Also check your fan motor. last. I have changed hundreds of caps this year. Russ
Posted on Jul 18, 2009
  • 13 Answers
SOURCE: Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
With power off, locate fan motor capacitor (generally silver in colour).
Rating on capacitor will be in microfarads at specified voltage ( 5mf @
370 volts). Be careful to discharge before handling and return defective
cap. to source of replacement. They can confirm whether or not truely
defective. Replace and secure. Restore power and check operation.
Purpose of run capacitor is to provide starting torque that you are
presently providing by hand spinning. Hope this helps.
Posted on Aug 05, 2009
How to fix goodman furnance A30-15 the blower wont turn on ?
Check capacitor, cheap replacement and easy to do, also spin blower wheel by hand to see if it moves freely. If so could be Cap. U can also try canding blower speeds to see if one of the speeds burnt out. Warranty??
Jun 09, 2014 | Goodman Heating & Cooling
Air conditioner hum often
Is your AC unit a wall mounted unit or a cassette ? And do you know if it has a pump fitted or if its gravity fed drain system
Jul 08, 2012 | Goodman Heating & Cooling
Goodman A18-8 electronic furnance and AC troubleshooting.
Check the unit for a high temperature limit switch, usually a round bimetal disc or a square plate that
would insert into the unit. If the switch is bad, it opens up and the fan will run no matter what. Complete the circuit with jumper wire, if fan shuts off
replace switch
Jun 12, 2010 | Goodman GMS90703BXA Heater
The furnance ignites for about ten seconds the right befor the blower comes on the furnance goes out. This repeats itself over and over until the unit shuts itself down.
Take out the flame sensor and clean it with a piece of sand paper or emery cloth and put it back in and this should get sustained flame.2e77348.jpg
Feb 25, 2010 | Goodman GMS90703BXA Heater
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Feb 28, 2009 | Goodman GMS90703BXA Heater
Gas furnance won't stay lit.
have a furnace man take a look it sounds like the itermitter control
Feb 05, 2009 | Goodman GMS80904BNA Open Flame Mid-Size...
Furnance will not come on
No Blink? no call for heat. Check thermostat. Jump out thermostat. Check the fuse in the cabinet as well as in the breaker box. Do you have an emergency switch that may have been turned off? Make sure the door interlock switch is closed and working.
Jan 29, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
