Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Model Number: mex731cas1 Brand: Electrolux Age:
Model Number: mex731cas1 Brand: Electrolux Age: 6-10 years The other day I noticed that my washer isn't starting cold cycles anymore. I have to choose warm cycle and the stops just before the final rinse. Best way to describe this is to see the video below: http://www.dailymotion.com/video/x1695gh_mex731cas1-cannot-select-cold-cycle_tech Anyone have an idea what's wrong?
  • Official Brand Answer
  • 4,342 Answers
Hello Tuomas, thank you for allowing me to assist you!
Based on the video you have provided, it shows that your laundry center is experiencing one or two things, an issue with the water valve or a faulty timer. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. I hope this information helps to some degree.
Best regards!
Posted on Oct 22, 2013
  • Tuomas Tarvainen
    Tuomas Tarvainen Oct 26, 2013
    I replaced the Water Valve with a new one and it didn't fix the problem. Next i'll try and find a used timer and see if that works.
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
SOURCE: My Frigidaire GLTR1670A stops when it gets to rinse???
It is much easier to take off the front panel than the back panel. You were correct there was a hairband clogging the drain hose trap.
Posted on Jun 13, 2007
SOURCE: Frigidaire Front load washer FTF2140FS
I HAD THAT TOO I UNPLUNG IT FOR 30 MINTUES AND WHEN PRESS START AND CANCEL TOGETHER AND PLUNG IT BACK ON IT SHOULD BLINK A FEW TIME THEN STOP . IF THIS DOESNT WORK THEN REMOVE IT AND MAKE SURE NOTHING CAME LOSE AND PLUG IT IT AND IF THEN NOTHING HAPPENS SORRY ITS BROKEN REPLACE CONTROL PANNEL.
30-50 $$ NOT MAD AT ALL
Posted on Nov 10, 2008
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
Posted on Feb 23, 2009
  • 396 Answers
SOURCE: Frigidaire GLTF2940FS...does not do a final spin/clothes wet
If water remains in the drum the unit will not go into the final spin.There may be a couple of reasons for your problem.
1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water.
2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning.
3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. I believe the pump is about $60.00 and is accessible after removing the front panel under the door.
Posted on Sep 10, 2009
My ewf10751 electrolux has working only with washing after i turning round it's knob. how to repair?
change timer may be striped knob age of washer your model posted is wrong check again
Apr 28, 2017 | Electrolux Washing Machines
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Just took my brand new Electrolux front load washer out of the box. Laid it on its back momentarily and noticed some water. Is this normal for a new machine to have this?
Good Afternoon Dodgerfan66, thank you for your post!
I understand that you received a new Electrolux washer and there was water inside of it. It is normal to have some water inside of your washer. Most manufacturers' test product prior to shipment and unfortunately it is difficult to drain every drop of water. I hope this information is helpful. -Matt
Mar 15, 2015 | Electrolux Washing Machines
How do i find the year of my sears washer
Your Kenmore is a Whirlpool.
Therefore, you need the serial number to determine the year. The second digit in the serial number is the year code.
You can find the lookup table here:
Determining the Age of Your Whirlpool Appliance
Oct 21, 2014 | Sears 4.5 cu. ft. Top-Load Washer
I recently bought a used Maytag Washer. Is there a way to tell the year-model by the serial number or model number?? Thank you for your help---Gordon, at grsll@sbcglobal.net
The age is determined by the last two LETTERS in the Serial Number (the first letter is the YEAR, the second letter is the MONTH). If you post back with the information I can tell you when the washer was manufactured.
Jul 25, 2009 | Washing Machines
Both drum and agitator spin during wash cycle. Is this normal?
What is the age and model number of the washer? It could be as simple as a problem with a part inside the agitator or it could be a bad transmission. A complete model and serial number from the washer not the book.
Jan 10, 2009 | Washing Machines
Washer overflows
Hello docjhon174
Welcome to fizya,
You said, you washer over flows. water valve is ok also checked pressure switch. its ok
Can you send your brand ,model number and the year or age of your washer?
Waiting for this important info!
Huuum
Oct 08, 2008 | Dryers
How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
hello Boonk
welcome to fixya,
We need to know the brand and model number to help you.
The year or age of the laundry center could prove valuable too!!!!!
You asked ,How do you remove the dryer from the stackable kit. I'm trying to take the dryer off the washer for repairs.
Waiting for this info. huuum
Oct 08, 2008 | Samsung Dryers
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
386 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
