Question about Exercise & Fitness
Pacemaster gold elite giving error code 133. Checked all connections so far and continuity through wire connecting top and bottom boards. No luck
    Top Expert:
  • 12,223 Answers
Please reset the treadmill, follow this steps and fix it. God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Posted on Oct 22, 2013
  • Jesus Curbelo
    Jesus Curbelo Feb 01, 2017
    Hello, where can I find the reset key/button?
3 Suggested Answers
  • 33 Answers
SOURCE: My cardiozone treadmill will countdown for 3 sec,
Your problem might be that a magnet has fallen off. Here's an illustrated guide which should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 1796 Answers
SOURCE: Where is the elevation fuse on a Pacemaster Gold
Hi!!
On page 6 of your owner's manual, step 3 shows a diagram to remove the shipping bolts. On that diagram, you can see the motor and the power cord wrapped around it.
Click on the following link to get a copy of your owner's manual on .pdf format, scroll to page six and magnify it to 400%, you should be able to see the blue circuit board and two white fuses. Make sure your Pacemaster is disconnected before working on the fuses.
http://www.pacemaster.com/manualPDF/PremiereGoldEliteFoldup.pdf
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 06, 2010
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
I have a Pacemaster Gold treadmill that will not hold elevation. I have no error codes. It will go to the proper elevation and then immediately start descending. If I change the elevation setting it will...
Run the utility software calibration for easy diagnostic, and fix it.
Go to HOOD open the cover motor and follow the steps indicated. or your owner manual.
God bless you
Sep 30, 2013 | PaceMaster Gold Elite Treadmill Upper...
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
Error message 133
It is an error code that refers to a black cable that attaches to the main circuit board located by the motor. It looks like a fat telephone wire. Unplug it and reinsert at both ends but try the bottom one first as it is easier to get to. If doing this does not work you can meter the pins on the cable to make sure that there is not a problem with it or you can replace it. If the cable is good and you continue to get that error then you will have to replace the power circuit board. I hope this isn't the case because they cost around $450.
Jan 25, 2013 | PaceMaster Premiere EXT Treadmill
F32
The F32 error code indicates a water level pressure switch failure. This is normally caused by wiring connection problem or a failed pressure switch. If you are able to unplug the washer and remove the top panel, you can check the wiring connections between the control board and the water level pressure switch. To remove the top panel (with the washer unplugged), take out the screws at the very back of the top panel and slide the panel back and then pick it up and remove it from the top of the washer. The pressure switch is on the top of the right side panel toward the back of the washer.
If the wire harness connection between the pressure switch and the control board is okay, then you will probably need to replace the pressure switch to correct this problem. The part number for the pressure switch is 8181695. You can order this part from the Sears PartsDirect website www.searspartsdirect.com .
The F28 error code indicates a communication error between the main control board and the motor control board at the bottom of the washer by the drive motor. A loose wiring harness connection can cause this problem. It can also be caused by a failed motor control board, a bad drive motor or a defective main control board. You may be able to check the wiring harness connection to the motor control board by unplugging the washer and removing the bottom from service panel. To remove this panel (with the washer unplugged), take out the screws at the very bottom of the panel and then pull the panel down and out to remove it. Access to the motor control board may be limited. You may be able to check to make sure that wiring connections are firmly secured on the motor control board. If the connections are okay and you continue to get the F28 error code, you may need to replace the motor control board.
Nov 02, 2010 | Kenmore HE2 Plus Front Load Washer
I have a kenmore elite top loader and it starts the cycle but like two minutes into the cycle it stops and shows a flashing f this happened about two months ago and the guy said that it was two wires on...
Well the error code indicates a problem with the door latch assembly. Do you hear any clicking sound? If it fails to latch, the wash cycle will not start and the error code and audible beep will occur. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics...... remove the top panel and with the two screws out of the door switch assy you will reach down and pull it up and swap the wire plugs and re-install it..... the price is aprox. $50.... Please post comments for more help or information.........
Good Luck!!
Thanks
Feb 14, 2010 | Kenmore Elite 45986 Front Load Washer
On my Kenmore Elite Bottom Freezer Refrigerator, the display on the left door reads ErCo and the ice maker does not work . Its less than 2 years old
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control Pad displays Er CO.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Exercise & Fitness Logo
1,481 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
