Question about Vehicle Parts & Accessories
Just bought 02 dodge 1500 pickup . I have no remote and I need to get it started . All I know is that the brand of the alarm is a Clifford . Can you please help ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 162 Answers
Look under the driver side of the dash, find the brain or control unit. Copy all the serial numbers down you can find on it. Good the serial #. Get the model of the unit and eBay a remote
Posted on Oct 22, 2013
  • 265 Answers
SOURCE: car alarm wont turn off
Try changing the batterys in the remotes mate
Posted on Feb 16, 2009
  • 22 Answers
SOURCE: mazda rx8 alarm
Search through the area in the footwell of the drivers side. There will be a very small button. This is a valet/progaming button that is on all aftermarkets. It may be by itself, it may be connected to the brain unit, or it could even be attached to the alarm antenna, which is usually on the windshield. You need to press this button when turning on the car some alarms you need to hold the button down others you just need to press it. This will shut off the alarm until it is reactivated with the key fob.
Posted on Dec 04, 2008
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
SOURCE: clifford alarm 7000 how to fix troubleshoot
snap , they are **** , cant even start my nissan , it just keeps locking and unlocking the car ....and nothing ggrrrrrrr
Posted on Feb 09, 2011
SOURCE: my car will not start
I am having the same problem with my 91 integra, anyone now a fix?
Posted on Mar 24, 2011
How I can get a service repair business for the diagnosis of a Clifford car alarm system?
First replaced the batteries, you may find a CR2032 in there easy to replace then try before blaming any other components
Aug 03, 2014 | Brand Remote Start/keyless/car Alarm Very...
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Constant sounds coming from my truck alarm
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Jan 03, 2014 | 5704x 570.x 2-Way Security and Remote...
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
How to disconnect factory alarm on 2001 dodge ram 1500
The factory alarm or VTSS as Chrysler calls it, is integral to the CTM and PCM computers in the truck. The only way I know to remove it is by sending it to a service like SOS Diagnostics to have the 2 computers reprogrammed. http://sosdiagnostics.com/chrysler/ You could also buy used ECU's from a different truck without alarm, but you might run into VIN mismatch problems with your ABS.
Sep 17, 2012 | Ram Pickup Alarm Remote Auto Start...
I'm having a issue with our 1998 dodge ram 1500 4x4 V6, it started when I disconnected the battery to put it in a jeep, I reconnected the same battery back into the dodge to find the alarm lights flashing...
Reset switch locater on pos cable link in black box located on firewall drivers side. most people remove these sometimes. sometimes they can be located in fuse box. if you have alarm remote try reseting it by removeing batter in remote then reinstall or replace
Mar 22, 2011 | 1998 Dodge Ram 1500 4WD
Clifford alarm 7000 how to fix troubleshoot
Dec 13, 2009 | Vehicle Parts & Accessories
Remote starter will not restart my vehicle
If you have an alarm, or remote start with an alarm, you need to press and hold thethe valet button which would be hidden under the dash on the driver side, as you are turning the key sometimes remote starts have a starter disable or an alarm option to reset it that is what needs to be done, some systems even if you dont have an alarm go into a valet mode if your remote battery is old or you never reset it or the alarm kicked in or what have you. if this does not work for you then you will need to bring it to a dealership and have them do a total reset to the computer you can also try disconnecting the negative battery cable, but do this with the door open cause it will reset everything, and google the reset procedure for the key fob (remote).. do that reset for the remote and it should save you money from having to bring it to a shop or dealer.
hope this helps.
Mar 01, 2009 | DEI Python 1400XP Remote Start/Keyless...
Vehicle Parts & Accessories Logo
135 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
