Question about Whirlpool GH7155XHS Microwave Oven
Yesterday I started heating food in the microwave and immediately heard a loud popping noise. I stopped it to see if there was metal inside. which of course there wasn't any. It now won't heat and the turntable won't turn. Otherwise it appears to be fine. Could this be a complex, expensive fix. It may be covered under our new home owners warranty, but there is a min $100 charge for each claim.
    Sergeant:
  • 139 Answers
There is an internal fuse but if you still have power on the display then likely the main transformer has failed and the cost to repair will likely exceed a replacement.
Posted on Aug 12, 2017
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Microwave heating problems
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Posted on Oct 03, 2008
  • 121 Answers
SOURCE: Yesterday, I went to use the microwave and as I
sounds like your magnetron went out . check how old it is, sometimes the manufacture gives a 5-10 yr warrenty on part if no warranty on unit then it may not be worth fixing depending on how much u spent on it. part roughly 89.99-139.99 labor 85-165.00 depending on who u use and were u live. hope this helps . thanx..
Posted on Oct 07, 2009
SOURCE: I have a Whirlpool Gold
I have the same problem with mine. The problem is the rubber piece on one of the 4 corners has come off and now when you heat things up the metal expose in the corners makes that noise as if aluminum foil is in there. It also makes burn marks where it sparked, further letting you know that there is exposure. Order new rubber covers for the corners.
Posted on Aug 02, 2011
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
My LG LRMP1270ST microwave oven stopped working in the morning. It just flat died when I put 2:00 minutes on the timer and pressed start I heard the pop/breaking sound. So immediately I stopped the...
The main fuse has blown in the microwave, you also have secondary problem that sounds like the magnetron has failed, but there are two other parts to consider, the high voltage capacitor and diode work in conjunction with the magnetron to heat the food. The repairs could run as high as a new microwave oven.
Feb 14, 2011 | LG Microwave Ovens
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
We have white
there is a component called a spatter gard inside the oven at the point where the microwaves enter......if food or other foreign substance gets stuck there, then it will start to burn ...the smell and popping noise is coming from the spatter gard.....to fix it you must remove the spatter gard..replace it if it's burnt and /or sand paper the spot clean and then paint the area with a high temperature paint called mr. touch up......to protect the bare metal from the microwaves.....hope that helps
Nov 27, 2009 | Kenmore 80412 Microwave Oven
I heard a pretty loud pop on my Sharp R-1505 yesterday and the microwave stopped heating. Any ideas?
get rid of it your transformer blew out they are to costly to replace and potintialy dangerous to work on unless you are trained technican
Oct 08, 2009 | Sharp R-1505 Microwave Oven
Saw sparks and heard a pop noise when we hit ''start'' on microwave
We just had the same problem - spark, loud noise, and then dead. At first I replaced the ceramic fuse and the same thing happened immediately. A local appliance store tested the transformer and found it was "bad." I purchased a used transformer from the store for about $35. I installed both of these myself with little effort.
Sep 08, 2009 | Dacor DMO24SS Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Microwave does not warm up food after big bang
oh ya man the heating coil is damaged so you have to change it.
Dec 13, 2007 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
44 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
