We have a Teac LCDV 1955HD for our caravan and want to connect to the 12v power supply via a cigarette plug connection ( no 240v supply) How do we do it?
    Top Expert:
  • 3,698 Answers
Buy a 115 volt inverted. they are available at all fuel station type truck stops.
Posted on Jun 26, 2014
What switch position should I have for 12v & 240v in a millard 2002 van
The 12v & 240v switch is to change voltage supplied to the camper. You use the 12v if you are running things from the battery; you use the 240 when you're connected to what the US calls "shore power" or "land power"
Mar 24, 2015 | Cars & Trucks
No 12volt supply unless connected to 240v mains
the power invertor could be the peoblem, or the fuse to the `12 volt supply sockets
Nov 09, 2014 | RVs
Sound from anything but cable?
Is my TV Teac model LCDV 2010M suitable for connection to digital TV or do I need a "box" for it?
Jul 11, 2013 | Coby TVDVD2050 20 in. TV/DVD Combo
Can a 12 v supply be used for ferg.f1604levd straight from a 12v battery
a 12V battery from car??
in cars battery are actually between 14V(fully charged) and 11V(empty)
else i don't know but the best way to be sure is using a regulator (this for example)
Nov 21, 2012 | Computers & Internet
Can i connect my tele in mt caravan on 12v
Yes. Either by using a 12v dc tv, or if it uses 120v/240v ac by using an inverter on the 12v dc supply which ups the voltage and converts to ac.
Jul 14, 2011 | Televison & Video
Need car adaptor for bmr100 12v to12v
As they don't make one you have 2 options.
1) Buy another Mains Adapter and Cigarette Lighter Plug, Cut the Cable & Connect to the BMR100 and connect it to the Cigarette Lighter Plug.
2) Buy a small (100W) 12V to 240V Inverter and plug your existing Mains Adapter into this. You'll get one from eBay for about £10.00 to £15.00.
May 05, 2011 | Makita BMR100 Radio
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
