Question about Refrigerators
Samsung srs585hdis side by side fridge freezer
Wont cool fridge, have tried all the relevant trouble shooting in the manual...heeeelllppp!!!
    New Friend:
  • 18 Answers
Fridges now a days get their cooling from the freezer, air is blowen in by a fan from the freezer to the fridge chamber, make sure the fans runing and duct work isn`t pluged.
Posted on Oct 22, 2013
Testimonial: "hi barry, sorry don't know much about fridges , where do I look for the duct work. thanks for your help"
    Top Expert:
  • Refrigerators Master
  • 44,926 Answers
The cold control inside the fridge may be defective. Hmmm...wonder why Samsung did not mention that as part of basic troubleshooting? If no adjustment of the cold control yields results, chances are it is defective.
Testimonial: "Thanks tom, it wont go any colder than 10 degreees. saw a post against another Samsung fridge regarding resetting the motherboard, might try that aswell.. appreciate your assistance, thankyou"
4 Suggested Answers
  • 27 Answers
SOURCE: Digital display is blank in GE Profile fridge
Hi. Its either a bad motherboard or control board. I would check the control board for any obvious signs of damage to the board first. I've seen the control board go blank on the GE side by side and it turned out to be the motherboard. The motherboard is located behind a cover on the back of your refrigerator cabinet. You should have a new motherboard on hand at all times because they fail alot. Be sure to put a surge protector on your refrigerator. Good Luck, Mack
Posted on Feb 02, 2008
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
  • 10 Answers
SOURCE: samsung SRS583HDP fridge not cooling. Side by side
Most likely the thermostat in the fridge, especially if it read 5 degrees until you reset it. Possibly the compressor in the fridge side as this fridge has twin cooling, or the circulating fan in the back of the fridge is frozen, which is a common problem as well.
Easiest things to try is to see if the fan is frozen and check if the fridge cooling is actually working. Turn off the fridge, remove the shelves, remove the 4 screws that hold in the bottom cover and the 2 screws that hold the water tank in. Cover should then come out a few inches. Reach behind and unplug the 2 plugs and pull out the cover. If the cover doesnt come out easily it may be glued to the back of the fridge by ice. Leave for a couple of hours and gently prize it off. Check for ice around the fan and that the fan spins freely. You could try sitting the cover inside the fridge, plug it in turn it back on for a few minutes (be careful) and then open the door and quickly look / listen to see if the fan is still spinning (it stops when you open the door). Leave the fridge off for a while until the ice disappears off the coils. Turn back on for half an hour. The coils should be icy again. Anything else call Samsung. If the deal in your country is the same as mine the fridge has a 2 year warranty but in the fine print the sealed compressor unit has five years on parts only. You could get the unit replaced for labour costs only. Check your warranty card.
Posted on May 05, 2011
How to check fan in samsung srs585hdis
Not really a good way to explain how to get to the fans but looking at the=> SRS585HDIS Parts Diagram may help you see what is in the way. You also can contact Big Warehouse Spares. Parts for your model HERE=> SAMSUNG Refrigerator SRS585HDIS (RS21HDUPN1/XSA) Parts If this refrigerator is like most dual evaporator refrigerators made by Samsung the fan will not be the problem. The problem is a design flaw that causes ice buildup on the fridge side evaporator. You can clean the defrost drain and manually defrost the evaporator with a hair drier.. That fix should last a couple months unless there is a door seal problem causing excessive moisture buildup on the refrigerator side evaporator. I am here should you have any questions, Thanks John Tripp Appliance 911
May 16, 2014 | Samsung Refrigerators
Samsung srs580dw fridge freezer after being
Most refrigerators get their cooling from the freezer. I suggest that you give it some time, and make sure the small door or damper leading from the freezer to the fridge is open and not obstructed by any food items
Aug 25, 2013 | Samsung RS2556 Side by Side Refrigerator
My Samsung side-by-side has stopped cooling - both freezer and fridge.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Samsung Refrigerators
Freezer wont freeze. Stuck at 35 degree. Fridge side is okay.
heatman101
Mar 10, 2011 | Samsung RS265LABP Side by Side...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Feb 10, 2010 | Samsung RS2556 Side by Side Refrigerator
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung side by side fridge freezer
bottom of fridge is freezing top of fridgeis not cooling?
Jan 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
718 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
