Question about Westinghouse Radio Communications
Power source is not functioning - Westinghouse Radio Communications
How do I set the time on a pioneer premier cd player?
1. Hold down source until power shuts off
2. Hold down function (fnc) button for several seconds until menu appears. (newer models that dont have the function button, hold down source a second time instead)
3. Every time function is pressed it go to next menu option
4. Use station tuning pad to set time
5. Push source when done
Apr 28, 2010 | Pioneer Premier DEH-P670MP CD Player
My alarm doesn't go off
You must try to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C power source.Then remove the Internal battery(CR2430). Let the Clock/Radio set without a power source for about 3 hours. This will discharge the microprocessor and reset it. After you have discharged the microprocessor,you can reinstall the internal battery. Connect the Clock/Radio to the A/C power source. The Clock/Radio's Functions should have returned to normal function. If the Clock/Radio did not return to normal function, you must replace the internal battery and again let the microprocessor discharge. After the microprocessor has discharged,put in the new internal battery and reconnect the Clock/Radio to the A/C power source. The Clock/Radio should have returned to normal function. If you are still having problem with the functions of the Clock/Radio, You will have to call Emerson Customer Support. The telephone number for the Emerson customer support is 1-800-909-1240. you can call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problems with the Clock/Radio. Thank you for using FixYa and have a nice day!
Jun 09, 2009 | Emerson Smartset Clock Radio
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Nov 19, 2008 | Emerson Smartset Clock Radio
Smart set
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Aug 15, 2008 | Emerson Smartset Clock Radio
Radio plays for no reason
Jul 27, 2008 | Emerson Smartset Clock Radio
Smart set clock dead ?
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
May 18, 2008 | Emerson Smartset Clock Radio
Smartset CKS 2288
Mar 09, 2008 | Emerson Smartset Clock Radio
Can't turn radio off or get anything else to work
Feb 19, 2008 | Emerson Smartset Clock Radio
Alarm
Feb 14, 2008 | Emerson Smartset Clock Radio
Alarm not working
Oct 26, 2007 | Emerson Smartset Clock Radio
Radio Communications Logo
71 people viewed this question
Top Westinghouse Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Westinghouse Radio Communication Expert? Answer questions, earn points and help others
