Question about Transcend StoreJet Computers & Internet
Fix hard disk
I connected my HDD StoreJet J25A3K a front USB panel and after that, Windows and Linux do not recognize. On Windows it's shown as Unknown device.
  • Transcend Master
  • 7,993 Answers
Unplug it, and restart the computer then plug it again in another USB port. Install the Windows drivers or any software that came with the HDD. What type of formatting does the HDD have? Linux file systems are not necessarily recognized by Windows based systems.
I
Posted on Oct 22, 2013
Testimonial: "Thanks for the reply, but still does not work."
    Scholar:
  • 112 Answers
With the device plugged in, open your device manager. The device should show a yellow exclamation mark next to it. Select it and delete it.
Unplug the device.
Power the computer completely off.
Plug the device into a different USB port (one you know works)
Boot it back up
If this doesn't fix it, repeat the process a few times with different ports and also using a different USB cable, if you have one.
If this still doesn't work, the troubleshooting gets significantly more complex.
Testimonial: "Michael I tried plugging it with another cable. Plugging it in different USB ports and following the steps you mention and it still doesn't working. It seems the troubleshooting is more complex. Thanks."
5 Suggested Answers
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
saqeb
  • 47 Answers
SOURCE: transcend storejet 25 mobile 160gb show error " usb device not re
Most probably your drive has been damaged. Try it on another system and if fails, no way
Posted on Jan 28, 2009
SOURCE: Notebook does not recognize My Book / Western Digital hard drive
I have solved a similar problem to this. My laptop would not allow me to get to my WD Passport. The driver was fine and no errors were reported - it recognised the drive when I ran the hardware removal utility - I just couldn't see it from any of my windows applications and therefore couldn't get to any data.
The problem was that the passport was being designated as E:\ but my laptop already has a network drive mapped to E:\. When I am in the office the computer connects the network drive to E:/ and so my passport automatically picks the next available letter - F:\. Away from the office, the network drive is still buit shows as "disconnected network drive" and somehow the laptop gets confused into designating both the the passport and the disconnected network drive to the same letter. so the passport is not visible in My Computer.
To fix it I went to My Computer, right clicked on the disconnected network drive and select Disconnect from the options there. And hey presto the passport appeared!
You can see which letter your USB HDD is assigned in the device manager in XP. Right click on the device and go to the Volumes tab - click on Populate and the drive letter should be shown there. If that doesn't match what you see under that letter in My Computer it looks like you have a similar problem & so disconnecting whatever is there in My computer might help.
Posted on Jun 07, 2009
Crankstart
  • 696 Answers
SOURCE: wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Posted on Jun 09, 2009
How can I retrieve saved data from my Transcend 2.5 StoreJet Portable HDD
Remove the drive and connect it to a known good USB adapter. If it still won't be recognised, buy a new drive. Sorry.
Jul 19, 2014 | Transcend 1TB 2.5 Inch StoreJet Mobile H2...
My transcend 320gb external hdd sometime disconnected automaticall. At present i can not even view my valuable data. If the folder inside the hdd are not show by my computer, how can i recovered my data...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have my StoreJet 25M 640GB external HD. I was transferring files from mycomp to the StoreJet yesterday when suddenly the transfer stopped( I was transferring video files, it happened 30mins since I...
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
hope this helps
Apr 12, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
One day i connected my Transcend storejet with Macbook laptop of my friend and when he clicked the drive,computer started to make backup.He stopped the backup process in between.After that when i connected...
This is because of the file system...Mac uses a different kind of file system, while windows uses a different one...
You need to format the hdd before using in windows machine...
because your HDD file system would have altered by MAC...
Now format the HDD from device manager and you will be able to see the HDD under windows explorer...
Feb 07, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
My Transcend StoreJet 500 GB external disk is not being recognized by my Win-XP System. No Messages, and No Errors Too.
first try to connect it from usb port at backside of cpu. if it works well ....ten do reply me .....
Sep 30, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
When I connect Storejet 2.5 through USB the explorer does not respond and when clicked my Computer icon the explorer screen does not display anything
Sounds like virus problems or the hard drive contains bad sectors and is stalling system when system tries accessing it. use a disk surface scanning tool.
Aug 08, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computers & Internet Logo
102 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
