Question about Panasonic PV-C2061 20 in. TV/VCR Combo
Loss of color - all green
The tv/vcr works great but the color is all green. Can this be repaired?
  • Gadawg07 Oct 01, 2007
    Where is the CRT board located? Opened the tv and not sure what equipment looks like to resolder the board. Any schematics available? Want to save myself repair bill and repair self as have minor experience in electromechanics. Thanks you for your help!
  • 790 Answers
Yes! the problem is in the CRT board the RGB colors! you have lost of blue and red! thats why your unit is green! and only green is worked the blue and red is not work! maybe you have lost contact of them! resolder all CRT board to comeback the normal picture!
Posted on Sep 28, 2007
  • Anonymous Oct 01, 2007
    the CRT is located at the back of picture tube! small square board that connects to picture tube!
SOURCE:
I purchased a used Panasonic Plasma TV TH-42Pw5. I finally got a picture by hooking it up through a vcr, but the color is completely green. When using the remote instruction colors are varied. HELP!
usually a single color is caused by a bad connection to the display I would guess that a connector inside the TV has come partially loose causing this this is quite common on the computers at my work due to vibration before taking the TV apart I suggest replacing the external cables to the VCR
Mar 25, 2017 | Panasonic Televison & Video
Sanyo DVW 7200 PS2 won't work
Tune the DVD/VCR to "channel 3".
Dec 18, 2013 | Sanyo DVW-7200 DVD/VCR
What color wires do i need to hook up the vcr player? The dvd player works with red/blue/green
Colors dont matter as long as you hook video on VCR to video on TV witch is usually yellow and left and right audio to L&R audio on TV witch is usually red and white.
Jul 17, 2011 | RCA Televison & Video
Red Color not working
Does this only show up in one connection IE: HD cable box, DVD player etc, If connected to a HD cable box a loss of red can mean a defective red component cable.
Aug 15, 2009 | Televison & Video
No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
We just received a big screen tv as a gift and we want to hook up our dvd player and our vcr and have lost the manuals. HELP
You can hook your dvd player in tv by using component video input terminal having green-red-blue colors for video signal and red-white for audio signal. so total 5 wires been used here. color order should be exact at both units, tv and dvd player i.e green to green, blue to blue and so on.
vcr can be hooked at composite video input in tv having 3 pins, yellow for video, red-white for audio in both units, vcr and tv. pins color should be exact on both units.
need further help, post here please.
Sep 24, 2008 | Televison & Video
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Loss of color when watching dvds
Uh oh, time for a shop visit as the chroma processor is not working properly....accordianman
Jul 03, 2008 | GoVideo DV2150 DVD Player/VCR
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
292 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
