Question about Acer TravelMate 2451WLMi Notebook
2451wlmi drivers travelmate - Acer TravelMate 2451WLMi Notebook
My wireless button wont work on my acer laptop
In window 7..you can go to control panel, then network and sharing center, then click on, change adapter settings, then click on the wireless adapter, and it should enable it then...
Aug 28, 2014 | Acer TRAVELMATE 2451WLMI COMPATIBLE LAPTOP...
My wireless button wont turn on
hi,
1, check and replaced button
2,re install device driver
Toshiba safelite c600 wireless
Look on both sides and the front of the laptop for the wireless switch.
May 07, 2012 | Acer TravelMate 2451WLMi (S6156810) PC...
My Notebook acer travelmate 2450 doesn't start correctly. After boot, only appears the following msg "operation system not found". Futhermore, I can't boot linux or windows by CDROM, because when I open...
Check with someone you know to see if they have a USB external CD or DVD drive that you can borrow. Then set it to boot from USB. There is also a possiblity that you have a corrupt CMOS fireware. See if you can download an BIOS firmware update and place it on a external floppy and install. Good Luck
Apr 27, 2010 | Acer TravelMate 2451WLMi Notebook
Problem with mouse and keyboard
you either loosened the cables going to the board for the keybboard and touchpad or have a briged solder joint.
Jul 26, 2009 | Acer TravelMate 2451WLMi Notebook
Recovery CD
Other way to restore ur notebook to factory default settings without recovery disks is
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
U can make a new set of Recovery disk when ur OS is running u will see Acer Empowering Technology with e sign kindly select ERecovery in the options and then u can make full backup of ur OS thru it
Pls rate me FIXYA fo rhelp
Apr 11, 2009 | Acer TravelMate 2451WLMi Notebook
Cannot recognized usb after i used mp3
Very likely a need for driver updates, assuming you don't have a hardware issue. Since detecting the type of equipment you have, and its numerous technical specifications, can be quite difficult, it may be easiest to use a site that will scan your system and determine the updates needed. Three available sites: driveragent.com, drivers.com, and drivershq.com. If you can't get it fixed in this fashion, please respond back with more detail about exactly what has occurred chronologically. Hopefully you will be all set, and thanks for rating FixYa!
Apr 25, 2008 | Electronics - Others
Display
Can u see bright screen when ur Ac adpator is pluged in.
if u can,
then,
change the battery setting in the power management options.
set use maximum battery option.
Jan 04, 2008 | Acer TravelMate 2451WLMi Notebook
I need guide about the buttoms in the front
Try the Acer website and check the support for your model see if you get any where with that
Nov 27, 2007 | Acer TravelMate 2451WLMi Notebook
Acer TravelMate 2451WLMi Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
