Question about Sharp MX-3501N All-In-One Printer
How can I enable the staple option for printing to a Sharp MX-4111N? There is no auto-configuration option available when I right-click on the printer under the devices/printers from the Start menu.
    Novelist:
  • 140 Answers
Are you using the correct print driver? Many times, if the print driver is for a similar product, it may not have that option. It would be a good idea to see if you have the specific driver especially the PCL6 version.
Posted on Oct 22, 2013
  • Michelle
    Michelle Oct 22, 2013
    Thanks for the suggestion. The ability for me to manually update the driver has been blocked (it's a work PC) - will request a driver update from my IT support.
    Guru:
  • Sharp Expert
  • 62 Answers
i know this is an old thread, but if anyone stumbles upon this, here is the quick solution.
Copier Collin Houston TX Copier and Imaging Expert
Posted on Feb 23, 2015
SOURCE: Sharp copy/printer to staple Crystal Reports
this should be an option in your print driver make sure when you set up the print driver you added the accessories ie. a finisher
Posted on Jul 17, 2008
JackHeath
  • 1049 Answers
SOURCE: Can't disable / remove "Print Status Window" on Sharp Ar-M160/M200
Remove the printer software and use a generic Windows driver. That is the only way, since the status window is part of the driver software. If the printer is postscript enabled you can almost always use the HP laserjet 4 driver which is basically generic postscript.
Posted on Jul 29, 2008
tehnik_bdg
  • 91 Answers
SOURCE: sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Posted on Jun 23, 2009
Sharp Tech
  • 63 Answers
SOURCE: how do i use the auto configuration facility on a
While at the printer settings page of the copier on your PC under printer configuration there is an automatic configuration tab. Once you press this it will ask you to check the boxes with the arrow . The paper is set determined by the copier itself. You may need to check your copier settings to make sure it detects the correct paper in the tray. Also it is not recommended to install this way mainly because if the customer doesn't want to print color they are not able to change the printer condition settings at the individual PCs. So individual install is recommended.
Posted on Oct 18, 2009
Testimonial: "Thank you for prompt reply. I had already done auto config, but it didn't seem to affect the latest PC to be connected. User can still modify settings"
SOURCE: Jobs going to Sharp MX-C311, but printer not
Worked with Sharp Support- client was using accounting and passcode was not set
Posted on Jan 21, 2010
How do i stop my sharp copier from printing with line
Here is a short video I made on how to remove lines from copies/prints on Sharp copiers.
Mar 10, 2015 | Sharp Mx-4111n Multifunction Copier
MX M503n will not staple when printing.
It sounds like you have not configured your print driver. The good news is this is way easy to do. Go to your devices and printers and then right click the sharp and go to printer properties click the configure tab and then click auto configure then select the option that it recommends. This will only work if you are using a Sharp driver and not one of the universal windows drivfers.
Oct 01, 2014 | Sharp MX-M503N Copier, Network Printer,...
It says Rendering in the spool section of Job Status
I know this is from months ago but I'll post this reply so people in the future can see it:
You probably need to do an image memory clear on the machine to clear out the corrupted print job, delete it from the queue on your computer, then reboot the machine.
To do an image memory clear on a Sharp MX-4111N:
1. double tap the home button
2. touch the firmware version in the bottom right corner(it doesn't look like a button but it is)
3. a number pad will pop up, hit P * C *
4. you should now be in the simulation menu, hit 66, Mono, 10, mono, execute, yes.
Give the machine a minute to process, then it should reboot automatically. If at this point you cannot print, you need to clear the print queue on each computer and do another image memory clear.
Sep 30, 2014 | Sharp Mx-4111n Multifunction Copier
How to install hole punch setting on pc
You need to configure your print driver with the options that the machine has. Check out my How-To configure the sharp print driver.
How To Configure Sharp Print Drivers with Installed Options to print...
Aug 23, 2013 | Sharp MX-5111N Copier w/ 36 Month Warranty
I cannot staple from my computer
Add finisher in auto configuration in printer driver.
Aug 22, 2013 | Sharp Mx-M753n mx-M753n
Greyed out
If this is when you select this machine to print to, it may be because the print driver is not configured properly. Go to main driver under start, control panel, printer, right click on printer, select configuration, then auto configuration and select everything with a finger pointing to it. Then try again.
Feb 10, 2010 | Sharp MX-3501N All-In-One Printer
Wondering if you can help set up a sharp
go into printer properties and see if there is an option for color...
Dec 16, 2009 | Sharp MX-2300N Color Copier
Cant staple from driver but can staple directly from the machines panel ... particularly 8x14
Most Likely the issue is resolved by configuring the driver properly. If you right click the printer under Printers and faxes in your start menu you need to go to properties, then to the configuration tab and then to Auto Configuration. it will then communicate with the printer and find out what options are installed and then enable you to use stapling from your computer. Make sure to select where the hands are pointing also. thanks. you will understand.
May 15, 2009 | Sharp MX-3501N All-In-One Printer
Staple problem
Are you sure you have the correct sorter, they come with diff. options. the same model comes w/wo staples- w/wo book binding etc.
For example : w staples may be an AOor A1 model
wo maybe an AS or B1 model
Jul 17, 2008 | Sharp AR-407 Copier
Sharp MX-3501N All-In-One Printer Logo
642 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
