Question about Vizio VBR110 Player
Is a Vizio Blu-Ray player Model VBR110 Netflix compatible?
SOURCE: my vbr120 blu ray player
I have the same problem. While I don't have the permanent solution, I can tell you a few things. 1) You don't need to unplug, simply hold the power button down on the unit until it does a full reset (it normally just goes into standby mode when you tap the power off button). 2) I've noticed the locking only happens if I try to watch a netflix after I've used an optical disc between resets. IMO, I believe it's a problem with the system memory not updating and won't be solved unless they put out a specific firmware upgrade for it (unlikely on such a cheap player).
Posted on Feb 16, 2011
  • 16 Answers
SOURCE: our vizio blu ray player
Please inspect the HDMI connector on the back of the Blu-Ray player to make sure none of the pins (top and bottom) are not push back inside the connector. If there are return the unit for a another unit.
Posted on Feb 24, 2011
muntejaya
  • 10421 Answers
SOURCE: what is my code to hack the multi-region on my
Please get the code here : www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__hytg34
Posted on Feb 27, 2011
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
stfisher_65
SOURCE: How do you reset a vizio blu ray player to default?
Find System Settings on the Main Menu. Under System Settings there is an option to Reset To Factory Defaults. Under Reset To Factory Defaults you have options to Reset settings to Factory Default or Deactivate accounts.
Posted on Oct 22, 2012
Adding amazon app to blu-ray player
Unfortunately, no. All the apps that are on any Blu-Ray are added or removed by the manufacturer. In your case, Netflix pays Vizio to put their app on there. I've seen apps removed and added from players during updates. So unless Amazon and Vizio make some sort of an agreement, that player will never be able to access anymore than what was loaded on it when you bought it.
Jan 20, 2014 | Vizio VBR220 Blu-Ray Player
I lost my netflix connection on my vizio blu ray player
I've searched for an answer regarding vizio vbr231 netflix connect issue to no avail. so here are my 2 cents. I'm taking mine back to Costco and exchanging it! lol. so called experts want to char4ge depending on the level of urgency to you WTF! EF them,mofos, crudentials are they've installed the systems before. just sayin
Jun 17, 2012 | Vizio VBR231 Blu-Ray Player
Vizio bluray remote does not work
can be the remote is the problem.replace the batteries in the remote..if that does not work then buy another remote at partstore.com
Sep 13, 2011 | Vizio VBR110 Player
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
Blu ray disc will not play in vizio vbr110 player.
i feel your pain, i have the same player and the same BD wont play past the menu! i dont have a solution for this problem... but if u find a solution... email me at brt.brt.brt@hotmail.com thanks
Dec 31, 2009 | Televison & Video
Can a sony blu ray s350 accept movies with netflix
I just had a chat session with Sony and the BDP-350 Blu Ray can not stream video from Netflix or Amazon.
Julie_> Welcome to Sony Online Support. I'm Julie. Please allow me a moment to review your concern.
Julie_> Thanks for waiting, xxxx. I'll be glad to assist you with the information about the compatibility of the Blu-ray Player to stream the videos.
Julie_> I'm very sorry to inform you that the Blu-ray Player is not compatible to stream the videos from netflix.
Julie_> Only the BD-Live feature of the Blu-ray discs played in the Blu-ray Player can be streamed.
Julie_> At this point of time there are no Firmware updates available to make it compatible to stream the videos through Netflix. 12/2/2009
Aug 17, 2009 | Sony BDP-S350 Blu-Ray Player
Vizio VBR110 Player Logo
99 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
