Zebra zm400 - Office Equipment & Supplies
ashish13
  • 75 Answers
SOURCE: Some noise comes when printing
Here is the link for the Service Manual required which i uploaded for you... hope this resolves your issue...
http://www.adrive.com/home/downloadfile/136030403
Posted on Feb 12, 2009
  • 35 Answers
SOURCE: zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Posted on Feb 16, 2010
ozztech
  • 285 Answers
SOURCE: i have a zebra zm400
turn printer off, press PAUSE button, turn printer on and wait 5 seconds then release the button. The printer is going to print the test label, check if coming some withe lines across the print. try to clean the printhead and the rollar, if pressist, need to replace printhead.
Please check if the cable from the printhead is totaly plug-in
Posted on Nov 13, 2010
ozztech
  • 285 Answers
SOURCE: como cambiar ip de zebra zm400 desde el panel
you need to connect with some network to the ip adress coming on the setings, if you dont connect with network, that function not apper.
If connect, you be aple to change to IP estactic and the Gateway and the subnet mask.
Dont forget to save.
ozztech
  • 285 Answers
SOURCE: Printing and counting problem with Zebra
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
Posted on Mar 26, 2011
How to fix dissapear printing label for Zebra ZM400
Hi, please be more especific regarding issue, can be software issue or hardware issue.
Jun 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra zm400 does not want to print from file
Hy, what file? thanks. try driver from www.seagulscientific.com.
Jun 03, 2014 | Zebra ZM400 Thermal Label Printer -...
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
How to downgrade ZM400 printer firmware
If the firmware here is the one you have, contact their support direct and ask them for the older version. You won't find it anywhere else.
ZM400 Industrial Printer Support Downloads Zebra
Jul 26, 2017 | Zebra Office Equipment & Supplies
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Como cambiar ip de zebra zm400 desde el panel
Mar 19, 2010 | Zebra 203DPI Printer
Zebra zm400 turn printed info 180 degrees
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
How to load new labels
http://www.scanonline.com/Online-Store/ZM400-600
Download the ZM400/600 Quick Reference Guide on the right hand side of the page. They have a diagram on how to load labels.
There should also be one inside the printer - printed on the back wall...
Jul 10, 2009 | Zebra ZM400 Direct Thermal-Thermal...
Software needed for ZM400
Try Zebra Designer, it is free from the Zebra website. If you'd like to link to a database, you will need to pay for the software.
Jun 30, 2009 | Zebra Z4Mplus Label Printer
22 people viewed this question
jasbo
jasbo
