Question about Electronics - Others
Inverter red light
It was green an it spark then turn red what do I do to fix the problem
  • 438 Answers
Interesting problem, a red light generally indicates a fault and if the unit is not expensive than just buy a replacement, do you have knowledge of electronics? if so i might be able to help you if not buy a new one and try to get extended warranty, Inverters are notorious for faulting and without knolagege of the workings of the circuits you have no chance to fix it.
best regards Falco
Posted on Nov 05, 2013
When I turn on the TV the green light goes green to red to green to red. If I keep turning it on and off eventually I get a picture. The picture is very dark at first
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 26, 2015 | Akai Televison & Video
TV will not turn on, only flashes green status light on front constantly, any suggested fixes?
A button may be stuck down, this is what happened to my TV when a button was stuck.
Dec 08, 2015 | Mitsubishi LT55164 55 in LCD TV
Sylvania lc320sl1
in this television .if you see the digital television .its the inverter board. try a probe pull off the small cable of inverter board .and try to turn on the tv .if the light stay green the inverter is out. thanks
Dec 10, 2013 | Televison & Video
Blink on standby green after awhile then blink red
The blinking green light signals that the inverter board is charging the bulb. If the blinking goes to red it means that this process has failed because either the inverter board is not full operational or the bulb itself has failed.
Most likely you will have to replace the bulb - here it is
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Royal+Philips+Electronics/Philips+Lighting/F93087600RL/New.aspx
If this doesn't fix it then you will have to check the inverter and power boards and replace the failing one.
Here is the ballast/inverter
http://www.partstore.com/Part/Sony/Sony/KDSR60XBR1/Sony/Sony/146893613/New.aspx
Here is the power board
http://cgi.ebay.com/SONY-KDS-R60XBR1-G-POWER-SUPPLY-1-867-733-11-Free-S-H-/120703310513
Mar 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Why cant i get my tv to turn on ?
just worked on one of these, same problem, found a bad capacitor,1000uf 25volt, in power supply module.
Jan 06, 2010 | Proscan 19LA25Q 19 in. LCD Television
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Tv wont turn on no more it was fine this morning then is turn off i try turn on and off the power light turns green the click off again and it turns red flashin plus the sleep light red as well flashin plz...
I had a problem with my Sharp LC-15e1u where it will not turn on
by pressing the LARGE RED pb on top. The power button remains red. It also used to be green. Well I tinkered with it and
found by starting with the power OFF,
Press both Menu & TV/Video
Turn on by pressing the Big Red Button
The power lignt is red for one second then turns green.
The TV Then turns on leaving you on channel 58.
The volume control slides from 0-30-60 and back to 0.
Also there is a small "K" in the upper left corner of the screen.
I'm returning the unit for a Factory warrenty. I bought it on
clearance "AS IS".
I hope this helps...
Mar 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Electronics - Others Logo
224 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
