Question about Garden
Broken cast iron front end, need to know how to find one for a46" cut mower.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Do a search online for your model #... You have the model number correct ??? If not, then not only can I NOT help you but neither can the internet.
Posted on Oct 22, 2013
Need to know where all grease fitting areon husqvarna lgt2654
One on each front wheel rim. One on each end of the cast iron front axle. Three on the deck. They are on the top of each spindle. There are no other grease fittings.
Feb 01, 2017 | Husqvarna Garden
I have a Sears YT 4500 Lawn Tractor. How do I straighten the front tires. One points left and one points right. I can't find an adjustment on the tractor
Craftsman makes a wonderful mower for the money. I've had 2. Until a couple years ago, however, they all had a huge problem - the front axles on these mowers were not cast-iron like the better, more expensive mowers. Accordingly, if you did something to put the front wheels/axle in a serious bind (like catch a tire on a good size rock or building corner with the wheels turned and while backing up and looking backwards), you may have seriously damaged the front axle. Sometimes that can be corrected with placing bushings in there if it's not too bad, but from what you describe it sounds like you've blown up the front axle. That's why your front wheels are going in different directions. Next thing: awful noises and inability to steer properly. I blew out front axles on 2 Craftsman mowers and repaired each of them before buying machines with cast-iron axles - Cub Cadet, John Deere. As I recall, about $235 each time.Got tired of it! The good news is that now Craftsman is putting cast -iron axles on most all of their higher end tractors. You'll need to have this done professionally if you want to keep or sell the machine. Then, go with a good, strong cast-iron axle. You can't adjust this problem. Sorry, friend. . .
Aug 08, 2015 | Sears Garden
What is the head bolt torque setting
Briggs and Stratton repair manuals are available at all location ware B&S parts are sold except lowes and Home Depot. I have one in my garage the cast iron motors are different then the aluminum ones I will need the model number for the exact torque spec 60000-130000 is 140 170000-280000 is 165 Aluminum and cast Iron is 190 IN.LBS. THIS IS ALL IN IN., LBS.,
Oct 09, 2014 | Briggs & Stratton Garden
Front wheels out of alignment steering is hard to turn
Sounds like you got a Murray, Yardman, etc. Steering system is of very poor quality. Front axle has plastic bushing on spindles they break and don't take much abuse. Spindles bend very easy and so with these conditions steering becomes hard and unpleasant. Front axles are not there strong point. Jack up front of mower and check for loose, sloppy wheel conditions. Go from there. New bushings and parts are available at varies places. Best repair would be to think about a mower with a strong front axle. Cast iron, steel etc, rather than a stamped out thin metal one that will always give you problems. Who doesn't bump trees, curbs, yard ornaments etc.
Aug 15, 2014 | Garden
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
My exhaust is coming out at the front of the car not the rear
Do you mean broken off and stuck inside or broken off and fallen out? Broken off and fallen out in this case is a good thing. Sounds like you mean the exhaust is broken at the manifold but what isn't clear is which piece, the manifold or the exhaust pipe. The manifold is a part of the engine, the exhaust pipe is connected to the manifold via the flange you speak of so if it is broken (coming from the engine as a base point) before the flange you need to change the manifold (less likely - hardly ever breaks - usually made of cast iron or cast aluminium) or where they typically break just after the flange (exhaust pipes are notorious for rusting out here, you will need to replace the front exhaust pipe and donut (gasket within the flange). Due to the high heat in this area it is extremely common for the bolts holding the pipe to the manifold to not just be ceased to it (lube will probably do no good) but to actually weld (or forge if you will) themselves to the metal of the pipe, in which case you need to cut them out with a torch. A good mechanic can usually do this without damaging the manifold. That is why it is a good thing if they have broken off and fallen out, much easier to change then welded in bolts (which would not fall out). I say replace the front exhaust pipe because without knowing which year your protege is or if it has an after market exhaust I don't know for sure if it is a one piece system or more than one piece. If it is a one piece you will need to either change the whole thing or do some cutting and welding to piece a section in. In which case, I do not recommend cutting the new piece you purchase but if the old exhaust on the vehicle is in alright shape from the muffler back you may be able to section it off and just replace the front section. Piecing it together would require at least one more piece, one to contact the old pipe to the new which would also need to be welded on but this method can still be cheaper (most of the time). Anything other than a simple in/out replacement will require torches and obviously if the bolts are welded in it is not a simple in/out job.
Mar 25, 2014 | Mazda Protege Cars & Trucks
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
IM ROUGHING IN PLUMBING FOR A SHOWER TOILET AND SINK. 8 BY6 BATHROOM FROM SCRATCH CAST IRON STACK ALREADY CUT AROUND REMOVE CEMENT SHOULD THE WHOLE INCLUDING CLEAN OUT , REPLACE IT WITH PVC OR JUST CUT IN...
always replace cast iron if its not a problem to do so, especially if it looks rough or is leaking or rusting. there are simple special black neoprene boots used to connect cast iron to pvc and do not require anything but a screwdriver, no slovents or sealers are required. always check for leaks if you make an underground connection before you cement the spot back up. its better to use gravel to fill this area in if your particular situation will allow.
Jun 04, 2010 | Kohler Plumbing
Moved into house with damaged joint in external soil pipe from upstaira shower room
You didn't state the size of the pipe or if it is PVC(plastic) or Cast iron. Two rubber couplings can be used to repair the joint. A 12" section, 6" on either side of the joint needs to be cut out. Cut a piece of schedule 40 drain/waste pipe same diameter as existing pipe to size(just under 12"). Take two rubber couplings (sized for your pipe) and place on each end of pipe joint, and tighten clamps.
This fix will work on cast iron pipe, but there may be another means of repairing the joint, so get back to me with more info about the pipe and joint.
Aug 02, 2009 | Plumbing
Cutting cast iron soil pipe
Phil, I recommend a ratchet snap cutter as it will allow you to cut the pipe in a clean manner. These are available for rent at most major home improvement stores in the US. One can also rent one at a tool rental company. I rented mine for $35.00 the bulk of which was a deposit on the tool. Just a reminder when buying the coupling device ensure you ask for or get a 4 inch cast iron to 4 inch PVC coupling. A bit of vaseline will help you get the neoprene coupling to seat properly with the PVC if you encouter resistance. Good luck. If you need more assistance let me know.
Sep 25, 2008 | Plumbing
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
