Manual for toshiba dms r-1 - Computers & Internet
How do i do dms and dd on canon f-170 calculator?
I could not find the manual for the F-170. Could it be the F710?.
For the F-710 the key + doubles as a DMS-DD key. see screen capture.
Mar 24, 2014 | Canon F-710 Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
Dd to dms conversion
Press the DMS button to convert between decimal degrees and degrees-minutes-seconds.
The DMS button is marked with the degree, minute, and second symbols. It's located above the [ENG] key, which is located above the [8] key.
For full details, start with the "Degree, Minute, Second (Sexagesimal) Calculations" section beginning on page E-22 of the manual. If you need a manual, you may download a copy here.
Jan 19, 2012 | Casio FX-115ES Scientific Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
How do i calculate cos 30°24'
You must first set angle unit to degree.
Press the [MODE] key a certain number of times until you get to a screen that displays Deg Rad Grad. Press number key 1 to select degree.
Once this is done you can calculate trigonometric functions. To enter angles in DMS you have a key marked with degree symbol, a quotation mark, and a double quotation mark. In what follows that key is represented as DMS.
To calculate cos(30 deg 24')
[COS] 30 [DMS] 24[DMS] [=]
If you get an error message you will have to enter the seconds even if the value is 0
[COS] 30 [DMS] 24[DMS] 0 [DMS] [=]
Sep 11, 2010 | Casio FX-300MS Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
On this family of calculators, you do as follows
Enter the first number (degrees), ex:15
Press [2nd][APPS] (ANGLE) to access the Angle functions
Select [1: degree symbol] [ENTER]
Main screen shows 15 deg
Enter the minutes, ex 25
Press [2nd] [APPS](ANGLE) to access Angle functions
Select [2:' apostrophe] [ENTER]
Screen echoes 15 deg 25'
Enter the seconds number, ex 32
Press [2nd][+] (") to access the double quotation mark
Screen echoes 15 deg 25' 32"
Press [ENTER]
Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Jan 06, 2010 | Texas Instruments TI-85 Calculator
Converting degrees and minutes and seconds to radians
With the TI8x/TI8xPlus you can enter an angle in degrees (Angle mode must be set to degrees) and convert it into DMS representation the following way. Exemple
18.675 [2nd][ANGLE][4] [ENTER] gives 18deg 40' 30''
If Angle [MODE] is set to degrees you can enter a number in radians and convert it into degrees. Exemple How many degrees are ther in 1rad ?
[1][2nd][ANGLE][3] display 1 with a small r as superscrit. Pressing [ENTER] yields 57.29577951
To convert 1rad into DMS, takes a little effort but can be done: you have
to convert radians to degrees and the result [ANS] into DMS.
You cannot use an angle written in DMS in any calculation.
But if you want to convert an angle from degrees to radians enter your number and divide by 57.29577951
Hope it helps
Sep 02, 2009 | Texas Instruments TI-84 Plus Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Open Questions:
Toshiba Customer Care And Toll Free Number ' Dataalign 'Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
Jun 22, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
