Question about Sewing Machines
Omega Serger 303 SI thread keeps breaking. How to fix it.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 28 Answers
Make sure both needles are new and THE SAME SIZE. Look if there are any needle punctures onthe needle plate and stich fingers.
Machine Tech
Posted on Oct 25, 2013
SOURCE: my white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
SOURCE: bernina 2500DCET serger keeps breaking the centre
I have found with any serger I have used that you have to cut the looper (bottom) threads before re threading the needle threads. You then rethread the loopers.
If you don't do this, the needle threads keep breaking. Hope this helps.
Posted on Mar 02, 2009
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
  • 136 Answers
SOURCE: Janome Mylock 534D serger thread 4 (green guides) breaking
what issue?
Posted on Jul 07, 2009
SOURCE: I am having problems threading my serger,Brother 920D one of
I have a Brother 920 D I got it fixed Thank you
Posted on Nov 26, 2009
The top tread breaks after about 1inch when trying to do chain stich on my janome cover stich machine
Could be the result of several things. There could be some gunk or threads stuck in the tension disk. Be sure to remove the thread and rethread from the beginning in the order specified. ALWAYS RAISE the presser foot when threading!!!! If you haven't tried a brand new needle, do so, and make sure it is pushed all the way up and installed with the flat side facing the correct direction. Some machines recommend #90 as the largest needle to use. Also, perhaps the needle eye is too small to accommodate the thread. Watch where the thread is breaking to give you an idea of where the problem may originate. Try a different brand of thread. Sometimes black thread causes issues because the heavy dye affects the thread. Set the tensions at the midway point and then loosen the tension on that one needle. There could also be a burr or rough spot somewhere along the threadpath that is catching the thread. Last idea--could be a timing issue.
Serger needle thread breaking sewing discussion topic PatternReview com
http://www.amitymama.com/threads/anyone-have-an-idea-why-my-serger-needle-thread-keeps-breaking.280524
Make It Handmade Threading Your Serger or Overlocker
Help please Serger needle thread breaking
Sewing Machine Thread Keeps Breaking
Dec 08, 2016 | Janome Sewing Machines
My serger is still not working properly trhread still breaking lower and upper
Generally, thread breakage is due to incorrect threading, threaded out of order, tension too tight, or the threads are looping or hanging up on their way through the thread path. Be sure to remove ALL the threads from the machine and RAISE the presser foot while threading. Give each thread an extra little tug when going through the thread tensioners to make sure they are seated all the way. Consult the owner's manual to verify the thread paths are correct and the threads are threaded in the specified order. (If not threaded in the proper order, the serger will most likely never work satisfactorily.) Perhaps changing thread brands will help--and avoid old or bargain bin threads. Set the tension guides to the midway point between high & low numbers before testing.
If there continue to be issues, the timing may be off or a looper may be bent. Take it for service.
Make It Handmade How to Thread Your Serger Out of Order
sewing patternreview com
https://answers.yahoo.com/question/index?qid=20120705022414AAvIeRH&submit=y
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
serger thread keeps breaking help
Mar 19, 2016 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
I have a bernette 134 and the tread keeps breaking , the lower loop thread , no matter how I set the tension , upper or lower this thread keeps breaking , HELP
10.check in the needle plate area to see if there is a burr
11. Check the looper to see if there is a burr or if it looks damaged
If all of the above suggestions don't help then the serger needs to be checked to see if there is something wrong with the loopers and also see if there is a problem with the tension.
Aug 22, 2013 | Sewing Machines
Janome 9200d overlocker
Aug 18, 2013 | Sewing Machines
Kenmore serger thread keeps breaking
Mar 26, 2013 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
Left needle thread keeps breaking on my White Superlock 2000 ATS serger
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
May 02, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
