Question about Admiral Washing Machines
My Admiral washing machine does not take on hot water. Filter is clean, hot water is running. any ideas?
    New Friend:
  • 50 Answers
Valve may not be working
Posted on Oct 22, 2013
4 Suggested Answers
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
SOURCE: Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Posted on Jan 12, 2011
My admiral washer will not fill up with water nor will it wash
Hello Melyssa
Have you tried both hot & cold water?
different settings?
stop mid cycle?
need more info
Jun 10, 2015 | Admiral Washing Machines
My washer smells moldy. Could it be filter don't know where it is located . It is admiral top load 2 speed heavy duty.
debra, I would run a hot water cycle without cloths, add clorex -clorine and a little detergent to the water. After the cycle fully runs, leave the lid open for few hours. It might help. Good Luck.
Dec 29, 2014 | Washing Machines
Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Jul 23, 2009 | Admiral AW22 Top Load Washer
Lint on dark clothes
no product i know of , try running machine without cloths with hot water and a lot of extra soap the unrestricted water movement and extra soap lubricates and helps to flush machine out, let machine dishcharge into bucket and if poor flow or lots of debris run again and see if this clears up you issue
Jul 07, 2009 | Washing Machines
My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
WHAT HOSE OR FITTINGS DO YOU NEED TO CONENCT ADMIRAL TOP LOADER WASHING MACHINES. UK HOSE SETS DON'T SEEM TO FIT! JON DAVIES
A standard hose should fit, they are standard on mine, you need good water pressure especially on hot, or you will find the hot water trickles into the machine when damanding hot water.
I use a seperate pump for the hot, the pump is connected to the hot valve supply and starts when hot water is required.
Jun 18, 2008 | Admiral Washing Machines
Admiral washer wont take in cold water
I to have the same problem except it is my hot water that dribbles
Dec 15, 2007 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
