Question about Admiral Washing Machines
Admiral heavy duty 8 cycle does not take in hot water
    Sergeant:
  • 317 Answers
Appear to be solenoid mixing valve...
Posted on Oct 22, 2013
SOURCE: admiral mega 22 plus heavy duty 2 speed washing machine
I think my set i just got today used is a 3 speed.Seems to be alright for now.There is a thing i was told called a harmonic balance it might be off or messed up.Tina.A(nc)
Posted on Apr 27, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Posted on Feb 26, 2009
  • 130 Answers
SOURCE: Admiral Designer Series Heavy Duty - stops in spin
you need to replace the motor coupling
Posted on Feb 28, 2009
  • 68 Answers
SOURCE: washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Posted on Dec 10, 2009
Testimonial: "Thank you so much!! I just saved the $ on going and buying a new machine. The lid switch was the problem..Merry Christmas!!"
My Admiral Heavy duty dryer is taking longer and longer to get clothes dry. Usually two cycles whereas, it used to take one. Help!
clean the lint trap really well and also check where it dumps the hot air outdoors . tat sometimes clogs with lint also .if this does not fix then replace the heating element
Aug 09, 2015 | Maytag Dryers
My washer smells moldy. Could it be filter don't know where it is located . It is admiral top load 2 speed heavy duty.
debra, I would run a hot water cycle without cloths, add clorex -clorine and a little detergent to the water. After the cycle fully runs, leave the lid open for few hours. It might help. Good Luck.
Dec 29, 2014 | Washing Machines
Sirs: Admiral Capacity Plus, heavy duty, during rise cycle did not shut off filling with water. Flooded laundry room. Shut-off incoming water and finished cycle, water spun out okay. Is there a sensor or...
Easy fix. Remove the control panel dust cover and look and see if that small hose is attached to that water level switch.1799041.jpg It may have vibrated off the switch. Air pressure is wat makes that switch work. If the hose is on there remove it and blow through it to remove any sediment that may be blocking the air. Reattach it and pump out the washer. Retry.
Jul 28, 2010 | Admiral Washing Machines
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
GWL15 no hot water on Regular or Heavy Duty Cycles
should you select a 40* wash it would not be right if the machine filled with hot water, as the water in the house tank is a lot more than 40* ( around 65* i think?) this would just damage the clothes and i am sure you would just complain again at that.
if the machine works fine then there is no problem
Oct 10, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
