I need a mirror for this TV any advice? - Televison & Video
  • Televison & ... Master
  • 3,204 Answers
You can have one cut at most diy place's its just a stander mirror. can even use the plastic type to replace them you can get them from hobby shop's cut cut to size glue or double sided fixing tape to hold back in place.
Posted on Oct 23, 2013
My left side mirror does not move in cold weather. any advice?
My best advice is to move to Florida , however if this is not in your plans then most likely the cold is making the mirror contract, causing it to bind . A replacement mirror unit will solve your issue.
Mar 21, 2013 | Jeep Liberty Cars & Trucks
Any advice about hanging mirrors?
You need to be sure that the wall you are hanging your mirror on can support the frame.
Take a look at this video which explains how to hang one safely;
http://www.potterybarn.com/design-studio/video/hang_a_mirror.html
Feb 18, 2013 | Home
I am looking for some clear advice on cleaning because so far my research is generating mixed messages. I have read 'don't clean it if you can still see a reflection' but I am considering photography so am...
You sound like you're talking about an slr or dslr camera. The advice is correct....do not under any circumstances touch or try to clean the mirror.
Jan 07, 2011 | Cameras
Craked right side mirror non-heated
all your answers are at www.burcoinc.com
DO NOT have a house hold mirror cut and installed. install a automotive mirror according to FMVSS111 (like the ones at burco)
Jan 06, 2009 | 2006 Ford Escape
Picture doesnt look as clear as before.
If the colors are mis-aligned or letters are out of focus, you may need to repair. For mis-alignment you can push the flash-focus button on the front to autoconverge the colors. Replacing the CRTs would cost a fortune. If the picture has just degraded in brightness and clarity, you cold clean it out. You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Dec 08, 2008 | Sony KP-53V85 53" Rear Projection...
Mirror Installation
You need to remove the two strips one on top and one on bottom of the plastic frame on the front of your tv. They can be easily flip up with a small screw driver. After removing the strip, you will see screws that hold the frame to the TV set, remove all of them then take the metal strip off. remove the frame, the protective cover, then remove the screen. The mirror then need to be sit on the slot of the back cover then hold it with the 3 brackets on the top on the inside of the rear cover.
Nov 17, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Replacing a drivers side mirror
There is a panel on the inside of the door where the mirror is.
That has to come off.
In some cases the door panel has to come off also.
Under the mirror panel there are nuts that hold the mirror on. Remove the nuts unplug the harness and install the new one.
Oct 07, 2008 | 2001 Jeep Grand Cherokee
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Broken Mirror
you need to see if the lens where the light comes out is scratched..
if it is then the picture will never be right until you replace it..as for a cheap replacement mirror the picture might be watchable if it is a good quality mirror
Aug 01, 2007 | Samsung HL-S6187W 61 in. HDTV
Picture not clear
When you say the picture is not clear please describe what you mean a little more clearly/ Thanks.
Mar 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
