Question about Husqvarna Garden
Can not open oil drain plug on MZ5225 - Husqvarna Garden
  • 71 Answers
Start at 7min 30sec mark. Will take 2 wrenches or 1 wrench and one rachet/socket.
Posted on Oct 22, 2013
  • 1 more comment
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Oct 22, 2013
    Great video eyekiltit... it shows a drain hose as I mentioned.
  • eyekiltit Oct 22, 2013
    I wish all movers were like this. Would make things so much easier.
    mowers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
For $100 you can buy a vacuum pump and **** it out or you can look on both sides and see if there is a drain hose or valve... If and only IF you have come to the conclusion that there is no drain valve or hose I would be saying something to the dealer that sold it to you !!! And I promise, being polite but angry will get your further than acting a fool.
Oil drain plug to open is anti clock wise
I don't think I have seen an oil drain plug that is left hand threaded, it may have been put in wrong and your thread is stripped either on the plug or the oil pan or both. Good luck
Aug 02, 2014 | 2001 Toyota Avalon
Where is the oil drain plug
you need to open it up...do you have to mix the oil and gas ??? then it cant leak oil...
Dec 27, 2013 | Hyundai HY2000si 2000W Portable Inverter
Can i change my oil filter without draining the oil from a separate bolt i.e open the oil filter, drain the oil from here and replace it with a new filter. Why? The bolt for draining the oil was damaged...
no. there is no other way. but the threads in your oil pan are alot harder than the threads on the drain plug, so chances are if you just replace the drain plug and put a thick gasket on it you should be ok
May 12, 2011 | 1997 Ford Expedition
Where is drain plug for engine oil in z4
OIL DRAIN PLUG IS ON THE BOTTOM OF OIL PAN JUST LOOK UNDER SUBFRAME UNDER THE ENGINE THE OIL DRAIN PLUG IS IN THE SMALL OPENING UNDER SUBFRAME.
Apr 22, 2011 | BMW Z4 Cars & Trucks
Procedure to change manual transmission fluid, 1995 honda accord.
There are two plugs on trany , one drain , one refiil.
Lift car and level it , open refill plug , set aside.
Open Drain plug and drain the oil.
Reinstall drain plug.
Use sifon pump to pump oil in to refill hole.
Fill it up untill oil start coming out of refill hole.
Reinstall refill plug.
You are done.
Plugs are for 22 or 24 mm wrench.One at the bottom the other one at level of drive axle of the transmission.They are same size.
Jun 16, 2010 | 1995 Honda Accord
Change the oil on a 2000 Dodge Caravan
Jack up pass side.Put cardboard, BIG piece under engine just in case. Using a pan to drain the oil in put under oil pan drain plug. Remove drain plug with socket wrench. Let drain 5 min. Check the gasket on the drain plug, if bad replace with new gasket .99 cents to replace gasket only on plug. Put plug back in DO NOT OVER TIGHTEN the plug. Slide drain pan with drained oil to the front to remove oil filter. Using a filter wrench remove oil filter. Let drain. When installing new filter put a little new engine oil on the rubber gasket on the filter with your finger. Screw filter back on tighten with filter wrench. Fill van with oil from front valve cover opening.
Nov 21, 2009 | 2000 Dodge Caravan
Need instructions for doing an oil change.
For doing on oil charge need to waste oilbasin ,new oil filter ,new oil canister.After that you need to run genine whith oil cleaner atleast 10 minutes,after wentilaiting ,stop the engine ,open drain plug and drain derty oil in waste oil basin,close drain plug, replase old oil filter ,fill in new oil.
Aug 09, 2009 | 2005 Mazda Tribute
Replacing fluids 0n 1996 300zx
radiator antifreeze: open drain **** on radiator and drain refill with water re plug and leave radiator cap off. start vehicle. watch when coolant drops or rises drastically as that is the thermostat opening. at that time re open drain **** and fill radiator with hose water at the same time. when water coming out is completely clear again turn vehicle off and drain radiator again. fill with antifreeze and water mix. 50/50
oil: jack up car, find oil plug, directly behind steering rack on oil pan. undo plug and drain oil into container. while oil is draining remove oil filter. wait for oil to drain completely then re-install drain plug and new oil filter(filled with oil) undo oil cap and pour in oil 4.5 quarts on n/a and 5 for turbo. tighten cap and your done.
brake system: dont attempt, use an experienced mechanic as the lines need to be bled in numerous places including inside the car from the abs module mounted behind the passenger seat.
easy brake system: individually bleed brakes while adding fluid until clear fluid comes out. (not efficient)
a/c: do not attempt unless you have an evac pump for ac systems.
clutch: same as easy brake except using the bleed valves at the slave cylinder and on passenger side fender well.
washer fluid: add fluid and squirt a little to make sure there is no air in the line
Jul 18, 2009 | 1996 Nissan 300ZX
Draining oil
Hi. I don't understand your statement about no oil coming out of "oil plug". Are you refering to the oil crankcase drain plug? This doesn't seem likely.
If you are experiencing oil in your air breather, this can be caused by two issues. 1. too much oil in the crankcase, 2. Blowby from the piston rings.
Bill
Nov 22, 2008 | 2000 Harley Davidson FXD Dyna Super Glide
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
