Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Need a capacitor for a model fg5700ak - McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Need part number for dual run capacitor for Armstrong Concept 10 air conditioner
The armstrong concept 10 comes in 7 different sizes. We need the model number off the outdoor unit.
Aug 08, 2017 | Heating & Cooling
How can I replace carburetor?
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
Jan 25, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Have a mcculloch fg5700ak portable generator. 7 yes old. Used 1 time for 20 hours. Sitting up since. Gas was drained so carburetor fine. Turn everything on and pull cord and it just won't kick on over and...
Make sure fuel tap is turned on. Tap the bottom of the carburettor with a wrench to make sure the float isn't stuck. Is the ignition on/off switch in the on position? make sure the oil level is ok as these usually have a low oil cutout which stops the motor when oil gets low. All that being ok give it full choke and it should start. Remove the sparkplug and check there is spark across the electrodes. (earth the thread part of plug on motor) If no spark replace the sparkplug.
Oct 03, 2014 | Electrical Supplies
Amana washer model lwa90aw how many microfarads in capacitor
It should be printed on the side of the capacitor but there are other ratings on it to consider as well,also the pin positions.
Nov 13, 2013 | Amana Washing Machines
Generator not making electric
You have a faulty inverter board on the unit. I would warranty the generator in this case, or have the manufacturer send you out a replacement board to swap yourself.
Aug 27, 2013 | McCulloch Fg5700ak 5,700 Watt Portable...
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
FG5700AK Low oil switch cuts engine almost off and then back on. Changed to lighter oil 10-30 and did not help. If I unhook the low oil switch it runs fine
Use a pressure gauge and make sure you have at least 10 psi, if you do then replace the oil pressure cutoff switch if this switch is bad no oil you put in it will fix the problem. If you don't then you have internal engines problems.
A lighter weight oil will only make the matter worse because its thinner and could actually cause the pressure to drop even further. If you have a low pressure problem you could try a heavier weight oil but its only going to increase it a little bit.
Nov 28, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Have an fg5700ak runs ok but no power output what
Typical diodes are 10 amp for these. The stator and rotor both have VERY low resistance readings. The reading typically will be below that which will register MEANINGFULLY on the digital meters.
My generator had 10 amp diodes with surge protectors across them. One of the protectors shorted and generator output was zero. Mine is a 6KW diesel silent unit.
Replaced the diodes with 70 amp ones with surge protectors that have 20 times the energy absorbtion as the originals. Unfortunately this required some lathe work to make holders for the diodes and the surge protectors to ride on the rotor.
Used the light bulb trick to remagnitize it once diodes were replaced.
Nov 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Low oil switch cut engine off and on when cold
It is not the oil switch you need to adjust the heads open the side and check on the settings for both in and out and adjust them according to the manual...in the winter sometimes they do not like heavy oil so check the oil weight and try lighter one
Nov 07, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
55 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
