Question about Vacuums
This torch no.GFL3882-1 can not work - Vacuums
Why is there no suction coming out from the rectangular hole on my dyson
is there something blocked in the tube ?
there is a spring /metal piece in the handle of the rigid section and bigger items get caught up then it catches smaller items making a dam to stop the suction take of t he hose section and have a butchers or shine a torch to see first i had to release the blockage with a stick
Jul 31, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to fit a foot release pedal on a samsung su2931 vacuum cleaner
I have a Samsung SU2920. The pedal has broken. Spare is available on espares. To remove the broken pedal:
Turn the machine over and locate the foot pedal side near a rear wheel.
Operate the pedal to see how it is held in place by a moulded pin which is captured by two lugs on the underside of the body. Use a torch to get some light in there.
Insert a thin blade on either side to bend the plastic lugs slightly so that the moulded pin on the foot pedal can slide upwards without being held by the lugs. The pedal will not slide up easily. I used a hammer and a metal bar to tap it free.
Once the pedal is removed, the spare can be clicked into place from the top without tools.
Jan 04, 2012 | Samsung Vacuums
After many years I have found , in excellent condition, my late husband's torch. Do I just attach the charger to the torch and plug into the mains, and wait ?
after all that time it is highly unlikely that the batteries will take a charge. Try it but I am sure you are going to need to replace the battery
Feb 16, 2011 | Vacuums
It is not picking up dirt
Was it picking up dirt before?
If so then perhaps the suction hose has a buildup of dirt/fluff somewhere along it. If a large piece of material went up the hose it often sticks and small bits gather around it to cause a complete blockage. Can you take the hose off and check? Or shine a torch down?
Dec 09, 2010 | Eureka Capture Upright Vacuum Vacuum
Geepas service centre ernakulam
my geepas tourch is not working, have your show room in malabar side
Jul 22, 2010 | Vacuums
It doesn't have any suction power. What do I look at first?
first you will need to look at the filters the filter on the right hand side of the unit is washable and can be cleaned the filter under the bin should be replaced every 6 months, if this does not improve then remove the bin assy from the unit and open the flap at the bottom and with a torch look down the middle of the cyclone you may find a blockage,also under the the cleaner head itself take a look at the clear hose as this may have a split of may even have fallen off hope this helps
Nov 01, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson dc07 seems to take awhile to build proper suction... is this normal?
no it should pick up as soon as you turn it on, make sure the brush is turning if it is then turn the unit off, make sure the the washable filter is clean and the the bin filter is also clean, if this does not work then there one more thing if you can try, remove the bin from the unit release the bin flap and with a torch look down the end of the cyclone you might find a large blockage this vry common in the dc07 hope this helps
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wand won't go into the flexible hose
try some fine sandpaper or one could heat up
the wand or hose with a heatgun or torch
to flex it and then try plugging it in.
Sep 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Having problems removing separator on Rainbow Vacuum....
Not a good sign. If your Rainbow is SE or newer - separator should not spin freely.
Some may recommend torch but I am afraid that you may end up melting some plastic parts so be careful. I'd say put a wrench on the nut, hold the separator and press it towards the motor (thus holding the armature as much as it is still possible) and then hit the wrench that is on the nut with another one - create momentum.
If this does not work - you can use pliers to destroy the separator completely so you would gain access to another nut that is under the separator so you can hold the armature with another wrench.
I can not guarantee 100% that you will succeed as sometimes those nuts are so rusted that you have to have the armature held in a vise.We usually disassemble the motor so we can hold the armature by hand or in a vise but if you do not want to go that far into the motor - use described above method - maybe it will work.
Nov 11, 2008 | Rainbow 75th Anniversary Canister Vacuum
Series e
First purchase a new aerator nut and aerator. Now spray where the nut meets the separator liberally with liquid wrench , let soak for an hr or 2 and then take a tooth brush to it at the same place. Don't try loosening it with a screw driver , use a deep well socket. Sorry I don't remember what size. if this doesn't work you can try a torch. To prevent this in the future thoroughly dry the tank after washing it and store with the aerator and nut OFF .
Sep 16, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
