My tv says it doesn't support resolution for a 75 ft hdmi cable. But it works for a five foot hdmi cable.
    Top Expert:
  • Televison & ... Master
  • 44,056 Answers
I agree with your TV.
Posted on Oct 22, 2013
SOURCE: akai lct42z6tm
I can confirm that replacing these 4 capacitors worked perfectly. I work in construction so i am not a technician or anything. I did not even have a solder iron. I have photos of the board if anyone would like to see them. Took me about a hour to replace the 4. I had to use (2)35volt & (2)50volt cause radio shack only had 2 of each and it works like a charm. This TV has been in storage for 6 months until i found this article on the problem. Cant say thanks enough!!!!!!!!!!
Posted on Jul 14, 2008
marketex
  • 371 Answers
SOURCE: TH-42PX60U All output ports works but HDMI ports
Problem is with your ISP/Cable Company accepting the installation as one with HD clients, which while
not necessarily costing you more, must be specified to the cable box by your installer.
Make the call.
Posted on Apr 17, 2009
romsky79
  • 822 Answers
SOURCE: My sharp LC-19DV22U Will not connect to my PS3
well alex welcome to fixya technical support online.i just read your problems. there is an option to your problem you can use another cables with RCA inputs capable in your PS3 that can works on videos and also you can buy video converter. thanks!
Posted on Aug 14, 2009
SOURCE: Bush iD HDMI 37inch tv hdmi problem
There should be a Zoom button on your remote control (Around the Teletext area, the word "WIDE" is below it) Select 'Zoom 1' and the TV Will display true 1920x1080 for your PC...
This is not a problem of any sort... for some reason the TV is defult to 'Zoom 2'
Peice of Cake.
Posted on Nov 07, 2009
aslemp
SOURCE: im getting a resolution mismatch
Having the same problem myself. Let me know if you figure out how to fix it.
Posted on Feb 10, 2011
I have an old rca gvibe plus gold tv is it a box i can buy to hook up cable,ps4 and xbox to it via hdmi ?
Obviously it needs a HDMI connection. If it has one, you can hook up all those devices. If it hasn't, no way
Apr 25, 2015 | RCA Televison & Video
I have a 55 inch led samsung was recently bought last year and we are running a 100 ft cable from an hdmi splitter to the TV. Just recently the image has a blue tint and frequently goes in and out. We have...
A 100-foot cable from an HDMI SPLITTER? Why? You were lucky it ever worked. Reliable (?) HDMI cables of that length are rare and VERY COSTLY. Add in a splitter (which reduces signal quality and strength) and you have the recipe for disaster. My suggestion is that you try to find a better way to arrange you setup to reduce the cable length to a manageable distance.
Dec 19, 2014 | Samsung UN50EH6000 50 LED HDTV
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
I have an longtime problem with my flm 3232 polaroid hdtv. I have dish network service with the dual receiver. The 3232 is the second tv connected via a coax cable. it work fine on the tv cable input...
Hello, you probably already have gotten this resolved, but I do have some answers to your post. Any cable that you have running from TV1 to the TV2 will nor give you a true HD picture. You could get a CAT5 cable with HDMI ends, but the longer the cable, the less true HD you have. The best resolution to this is to get an additional receiver, or to just stick with the SD picture. If you have any more questions, feel free to e-mail me at becki.barned@dishnetwork.com, or you can find us on Twitter!
Becki Barned
DISH Network Customer Service
Oct 14, 2010 | Polaroid FLM-3232 Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
