Question about Fasco Appalachian Wood Stove Blower Assembly
Need wiring diagram for applachian wood stove.
I have a drolet wood stove model # db03081 i need to know how many inches from the wall it has to be, i can't make out the diagram?
It is recommended that you have it 36 inches from an unprotected wall, if the wall is protected you can go down to 18".
Dec 31, 2016 | Home
I have a McClary Charm A2746 wood stove.I wanted to know what year it is?
Kathy, There should be a certification plate on the stove some where, listing make, model, year of manufacture, etc., open doors/drawers etc. to see if tag is riveted on inside panel or frame. Check the attached links they may help determine the age of your stove, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
McClary Charm A2746 wood stove Google Search
Antique stoves for sale
Ernie Woodstoves Durham Ontario Canada Repairs Restoration Sales
Strong on Stoves
mcclary wood stove history Google Search
Jul 15, 2016 | Home
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Need a wiring diagram for a rse37bal3
Your Frigidaire motorcycle has an electric stove?
Most stoves I have worked with in the past have had the wiring diagram glued either to the back or under the top. I have never seen one installed on a motorcycle, however.
Feb 16, 2013 | Motorcycles
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
I need to wire a 24 volt double pole double throw relay to operate a fan in a furnace parrell with a wood stove.
Your problem has really got me interested in what you are attempting to do. So are you looking to diable the FAU while the wood stove is heating or activate the blower motor for the FAU when the wood stove is hot?
Oct 30, 2009 | Goodman GMS90703BXA Heater
Fasco Appalachian Wood Stove Blower Assembly Logo
193 people viewed this question
Top Fasco Home Experts
john h
Tom Chichester
Are you a Fasco Home Expert? Answer questions, earn points and help others
