Question about Campbell Hausfeld Air Tools & Compressors
I have a CH VT629002 Compressor (5HP) 110V 20 Gallon. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it reaches 125psi, it shuts off and I hear the unloader valve hiss a small amount of pressure. When I then draw down the pressure to around 85psi, the pressure switch kicks the compressor back on and it tries to start, hums for a few seconds and trips the breaker. If I manually draw down the pressure with the switch off between 85psi and 50psi, it trips the breaker. However, if I draw it down to 40psi and turn it on, it will in fact start and run back up to 125psi. I suspect that the following are ok but am looking for advice before part shopping: - start capacitor is fine (runs with no load, from 0psi up to 40psi) - unloader valve is fine (hear it activate immediately upon compressor shutting off) - pressure valve? I think it may be fine as it kicks in at the prescribed 85psi and activates the compressor to turn on - Check Valve looks like the suspect, but I have no idea how to verify. Any thoughts?
  • Campbell Hau... Master
  • 9,742 Answers
Start capacitor is NOT ok. Check the centrifugal switch in the motor to see of it's not stuck in the run position too.
Posted on Jan 29, 2014
  • 1388 Answers
SOURCE: Air compressor w/5hp motor
Assuming that the motor is factory matched to pump, it should be powerful enough to turn the pump. Most problems with motors are related to pressure switch and/or capacitor. The pressure switch could have burned contacts causing low amps to reach the motor. The capacitor should test at least 90% of rated value printed on capacitor. Some volt meters have capacitor check setting. Also this motor at 5 hp must draw lots of amps. The outlet should be rated at least 20 amps and plug the compressor directly into oulet without an extension cord. \
Secondary problem is the in-tank check valve. The check valve should hold in tank pressure without leaking back to the head of the pump. If check valve leaks, replace it with any brand of same thread size. enjoy
Posted on Nov 29, 2008
  • 65 Answers
SOURCE: airmaster 15/50
hi dave your non return valve is passing air,you will find this if you follow the delivery pipe from your pump to your tank ,where it connects to the tank this is your nrv,there will be a hexagonnal plug ,BEFORE REMOVAL EMPTY YOUR TANK COMPLETELY.remove plug,inside you will either find a spring and a synthetic seal or a spring and sphere , if its just like a rubber like seal just replace the seal(sometimes you can simply turn it over),if its the ball type,then you will have to replace the whole valve,available from your local
compressed air service agent if you have any trouble finding one localy then contact myself at
service@icasair.co.uk
Posted on Mar 24, 2009
  • 14 Answers
SOURCE: Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Posted on Jul 19, 2009
protek480
  • 1714 Answers
SOURCE: air compressor motor won't stay on?
The pressure switch controls the motor on and off. Adjust the pressure switch up to increased the 'off' setting for higher pressure.
Posted on Sep 17, 2009
dmftrucker
  • 1922 Answers
SOURCE: When I start my compressor, it runs fine for one cycle
either the motor start capacitor is weak on the motor case(cheap fix) or the motor windings are defective(expensive fix) new motor time
Posted on Nov 01, 2009
Testimonial: "The reply was surprisingly prompt, within an hour or so. I'll get back to the site with my final results on the fix."
Puma compressor motor reset button
Breakers operate according the heat built up in them. The more amperage a circuit draws, the greater the heat that current produces in the breaker. Check to be sure the compressor is turning as freely as it should. If all is as it should be, the motor is overheating and should be replaced.
Dec 14, 2013 | Campbell Hausfeld 5HP 20 Gallon Single...
Which way does it spin?
Put it on. The big pulley is also a big fan. So it should blow air on the pumping unit. This is it. If it spins in the wrong direction change the polarity. If you look close you should see somvere a rotation direction indicator .
Nov 26, 2013 | Ingersoll Rand 2475N5-P 80 Gallon Vertical...
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
I have a PUMA air compressor that has been running fine until this morning, it will not run, I have power (220 ) to the wires at the pressure switch and the reset button was not tripped, motor and...
If you remove the fan belt and the motor runs without a load,
one of your motor capacitors is bad. some motors take one
capacitor, some take two. the capacitor is what helps the
the motor give that extra torque to run the compressor pump.
good luck!
Jul 17, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
The Electric motor does not have enough torque to start compressor. It is hooked up to 230V with 40 amp single phase. checked voltage with meter so I know it has enough voltage.
Does it trip the breaker or does the motor just hum and not turn the compressor? The motor may need a start capacitor. Do not keep tryin to start you can burn out the start winding on the motor.
TURN OFF POWER AND LOCK OUT.... try and take the belts off (if it has belts)of the motor and compressor and make sure both turn freely. IF THEY TURN FREELY THERE IS A PROBLEM WITH THE MOTOR. You said voltage, wire size and breakers are the right size.
Hope this helps you with your problem...Jim...please leave a comment
Feb 13, 2011 | Ingersoll Rand SS5L5 Ir Electric...
How do i change my craftsman 919165200 air compressor from 120v to 240v?
Your Craftsman model 919.165200, 5hp, 20 gallon compressor was designed to run on 115~120v 15amp. I believe that it was made by Campbell Hausfeld and is of the oilless single cylinder type. If however your compressor is oil lubed and has a motor /drive belt configuration it may be able to convert if there is a spec plate on the motor with alternate wiring diagram. Many high-end compressors like Rol Air, Jenny, Dewalt, etc with motor/belt drive have a switch selectable voltage, however one must still change the power cord when using 220v. Good luck with your projects and post again if your have other question.
Aug 02, 2010 | Craftsman Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
No psi
A louder motor usually means that it is running at a higher rpm. The most likely problem is bad seals around the compressor pistons. Once there is enough resistance to the seals they will begin to fail. As for a manual the best place to check is a CH authorized repair shop. Sometimes your local lawn mower shop will be able to assist you with parts help
Apr 22, 2009 | Air Tools & Compressors
Oct 29, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
139 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
