Question about Remington Garden
Need a switch for model rm193bvt - Remington Garden
How to reassemble the power switch on model 92504 air compressor
You can try but you can go online and find replacement pressure switches. The piping size is important my old one was1/4 inch, paid about $5-6 dollars on ebay. HF probably won't have part. If there is a model number on the switch body or inside cover that will help you. Al you need is one that the piping is correct and the switch Chas pressure range that you need. It is probably set for 120 psi off and 80 psi one. You can change it
May 16, 2017 | Air Tools & Compressors
Sir, I have Molinex Food Peo of model 370.It has started giving noise when switched on. More over its safety switch is also broken. need to replace safety switch. I feel the carbon brushes have been worn...
Sir, I have Moulinex Food Processor of model Master Chef 580 .It has Problem with the Moulinex DG6 6.34 Cups Food Processor Sir, I have Molinex Food Processor Master Chef model 580.It has started giving noise when switched on. More over it's safety switch is broken. need to replace safety switch.Also Motor's Rotor's winding is burnt.Needs rotors replacement. Please intimate service center &spare part supplying agency in India. I am in Vadodara (Gujarat) India
Jan 19, 2011 | Moulinex DG6 Food Processor
Model 05538 - Need the 5 button switch, what is
mcdevito75 here, Chances are only from the manufacturer, check out online at Tower fans.com Or maybe check with a Home Depot in your area for the switch.
Jul 20, 2010 | Tower Dryers
Door switch needs changing
There are videos at www.appliancehelponline.com/servicemanual.html that will walk you replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Apr 09, 2010 | KitchenAid KAWS700L Top Load Washer
Fuel cut off switch for 1990/91 ford escort 1.9
The "inertia switch" which shuts off fuel to the engine in the event of a collision or jolt on a 1991 through 1996 models, as well as on 1998 coupes, is located in the rear of the vehicle, near the right (passenger's side) strut tower. On sedan and coupe models, open the trunk and remove the right-sided trim panel. On sedan and coupe models, open the trunk and remove the right-side trim panel. On hatchback and wagon models, there may be an access door secured by clips. On some models you may need to remove the lower quarter trim panel on the right side, however it is easier to cut an access hole directly above the switch.
Dec 04, 2008 | 1991 Ford Escort
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Need to replace d3v-16g-3c25 for my sharp micro...where can I get it... .1 amp 124v dc
That sounds like a door switch. Which switch is it? Top, middle, bottom?
Is your model number R1480? If not, please reply back with your model number so we can help you.
The door switches in model R1480 are:
QSW-MA110WRE0 top & bottom switches
FFS-BA016/KIT middle monitor switch with fuse (kit)
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
But the best place to order Sharp parts is Tritronics.
If none of this info helps you, please reply back with your brand and model number and let me know which part you need.
Jul 29, 2008 | Sharp R-1480 Microwave Oven
Garden Logo
80 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
