Question about Emerson PD6810 CD Boombox
Aux inputs
I can't find what channel to get music from my Iphone that is plugged into my Aux In
  • 2,113 Answers
I found the manual I don't see what to do either
http://audio.manualsonline.com/manuals/mfg/emerson/pd6810.html?idRes=7373492
Posted on Oct 22, 2013
Why does my UREI 1620LE hiss on phono channels and aux 4 channel ?
are you using a phono pre on the phono channels?
Sep 15, 2014 | Music
Bought a 2011 Outlander 3 weeks ago. Thought it had the USB port but it doesn't. It does have the RCA connector, red and white. I have the IPhone 3. How do I hook it up to utilize my music??
Here's AUX cables for iPhones.
http://www.alibaba.com/showroom/3.5mm-usb-cable.html
By "RCA connector", I'm assuming that you mean the vehicle has an AUX input. Most AUX inputs are 3.5mm. If the Outlander actually uses a pair of RCA inputs, you will also need a cable with RCA plugs on one end and RCA plugs on the other.
Jun 17, 2011 | Car Audio & Video
How to connect effects processor to mackie 1602 mixer
Should be an Aux 1 or 2 output jack on the right side of the mixer. You can come out of the 1 or 2 OUTPUT jack to the input on your processor, and then from the output of the processor to Effects return or to a channel input. By going to a channel input you can then blend the processor's signal with a slider into the sound system with the other channels, while adding tone if needed. By going back into the Effects return, you just blend it overall by adjusting the Effects return knob.
To feed the channels through the processor, turn the AUX 1 or 2 knob up on each individual channel you want to go through the processor. Make sure the AUX 1 (or 2 if you are using that) MASTER knob is turned up on the right side of the console, otherwise nothing will go to the processor. You should see the processors' input light showing signal, if not check your connections. Good luck
Feb 19, 2011 | Mackie 1402-vlz3 Compact Mixer - 120v
I have an iPhone that I would like to be able to play thru my cd player. I got the aux 3.6 mm input jax. I connected the 2 and there was no music? Thanks
A couple of things might be happening: 1) Check that the miniplug tha you are using is STEREO (3 contacts), because otherwise, it will short the input. 2) Check that once plugged, you have the proper source selected in the pioneer headunit (AUX). 3) You will lose all of the iphone / ipod features unless you use the usb jack. I suggest that you buy the pioneer adapter to use these Apple devices.
Aug 15, 2010 | Pioneer DEH-P6800MP CD Player
Using iphone ipod with compact audio system.
If your audio unit has an audio input plug and an auxillary function, you should be able to run the 3.5mm jack from the headphones socket on your iphone to the audio input of your audio system, then select aux on the audio system and you should be able to hear any music played on your iphone through your audio unit. Good luck.
Jun 07, 2010 | Sharp KB6024MK 1000 Watts Microwave Oven
How do I connect monitors?
You run one or more of the AUX outputs to an amplifier then to a passive monitor, OR if you have powered monitors then you just run the AUX's as needed to the powered monitor(s)
You then adjust the "AUX" mix for each channel input to each of the AUX you are using for the monitors as needed.
Mar 19, 2010 | Peavey 32fx USB 32 Channel Mixer
Playing a iphone on a standard honda radio
you need to identify the AUX input (it should be in the rear of the unit). If it is a standard mini plug, then you can use your iphone. If it is a proprietary harness input then you will need to buy the appropriate hardware fron a honda dealer.
Mar 28, 2009 | Car Audio & Video
How do I setup the SoundMAX device for AUX line-out?
The cable from the computer simply needs to be plugged in to the speaker/headphone jack on the computer, then run to the AUX input on the amp. Make sure the volume on the computer is set to about 75% - 90%.
Apr 07, 2017 | NAD C320 2-Channel Amplifier
Aux. Input Jack
I had the same problem. I opened up the box and used a glue gun to reattach the aux jack from the inside.
Jun 18, 2008 | Bosch PB10-CD Radio/CD Boombox
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
Emerson PD6810 CD Boombox Logo
147 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
