Question about Lenovo Computers & Internet
The charging port for my lenovo thinkpad z560 seems loose and when the charging cable is plugged in it won't charge.
    Sergeant:
    Champion:
  • 212 Answers
Please chang adopter
Posted on Oct 22, 2013
myjosh007
  • 530 Answers
SOURCE: my lenovo it keeps shutting down
hi im josh in cebu phils. may i help you? Friend i encountered the same problem of yours before.and i was able to solve it. Friend the rechargeble battery/supply of your notebooks is the problem.change that with the new one. or before you do it try to see first if the connections are ok like loosening connection may cause these problem. dmage power chord may aslo cause or the socket of your note try to check if not loosen or weak or detached. good luck!
Posted on Feb 21, 2009
  • 1341 Answers
SOURCE: Lenovo Z560 laptop battery charge
A sudden drop from 50% to 7% means that the battery is faulty, it is simply a case where it is not holding any charge. I would suggest you contact the seller and check if the battery is under warranty. Hope this helps and good luck.Any question please feel free to ask.
Posted on Dec 30, 2010
Testimonial: "Yes. Thank you!"
  • 72 Answers
SOURCE: i have a laptop,i recently buy it. there is a
Your battery is at or nearing it's lifespan. Get a replacement battery.
Posted on Mar 09, 2011
rwss
  • 178 Answers
SOURCE: My computer won't charge! The
You'll need to contact Sony becouse the contact pin went loose on the motherboard
It needs to be resoldered to the motherboard.
Posted on May 21, 2011
prashant2012
  • 1127 Answers
SOURCE: If the battery is fully
Hi
Battery is not charge bcoz this already charged. please don;t over charge your Laptop battery this is harmfull for laptop
Posted on Jun 04, 2011
How to replace charger port on Lenovo tablet?
has to be sent in to a repair shop .check with Lenovo as to where they might be Official Lenovo Support Home Lenovo Support US
Aug 14, 2015 | Lenovo ThinkPad X60 Tablet PC
Lenovo thinkpad plugged in not charging is there a problem
laptop plugged in not charging:
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the IBM ThinkPad X40 power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Jan 01, 2013 | IBM Lenovo ThinkPad X40 Notebook
Battery not charging
Sounds like it could be two things with that, first look at the battery symbol, is it flashing orange or is it green. If its flashing orange means you have a bad battery, if its solid green all ok, if its switching between green and yellow its charging. if the symbol isn't lit at all it doesn't detect your battery and try to remove and reinsert battery. Next look at the plug light, is it green?
Dec 16, 2012 | Lenovo IdeaPad Z560 Notebook
IdeaPad Z560 79% available "Plugged in but not charging" message
Bad battery? Is the battery a replacement? Test cord/charger.
Nov 26, 2012 | Lenovo IdeaPad Z560 Notebook
Lenovo Ideapad Z570: Battery indicator shows the Power is plugged in & charging. But the Battery charge percentage doesn't increase. How to fix this?
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
May 14, 2012 | Lenovo IdeaPad Z560 Notebook
Lenovo z560 getting overheated and switched off
if you keep the mains charger plugged in all the time then this can cause the battery to heat up. if you use the laptop in the same position all the time then try removing the battery for use or when the battery is fully charged then remove the charger, this will also preserve the lifespan and battery operation.hope this is of help to you,
Apr 05, 2012 | Lenovo IdeaPad Z560 Notebook
If the battery is fully charged when i plug the charger stopped charging or not in Lenovo z560 ?
Welcome to FixYa
When the battery is fully charged and you still have the ac adapter plugged in then the battery would no longer be charged. The computer would then be running on ac adapter power.
hope this helps
Jun 04, 2011 | Lenovo IdeaPad Z560 Notebook
The laptop lenovo z560 does not switch on. With battery it shows 2 short flashes of battery charge idicator, an one long (about 10 sec) and than nothing is happening. Withou battery nothing happens after...
Hi smialkovskyi,
With this specific concern that you do have, unable to turn on your Lenovo Z560, there 3 components that need to be checked. Your battery, the AC adapter (charger) and as well as the DC In port.
1.Based on what you have said, with the battery alone you have noticed that it's led indicator will show however still can't turn on system. Battery seems to be in good condition however no enough charge to turn on the system.
2. For your AC adapter, when you're using it without the battery nothing happens. To check if this is defective try using another AC adapter that is compatible to your unit. If your computer turned on using another AC adapter then your charger needs replacement. (You may also try using your charger to other unit where it is compatible, just to test).
3. However, if after doing the previous instruction and still system won't turn on then it could be the DC In port which is defective. This port is built in to *********** board.
After doing all these you need to contact Lenovo. They might be replacing your charger or *********** board if system is under warranty.
Hope this helps.
Thank you for using Fixya.
Jan 28, 2011 | Lifetime Lenovo/IBM IdeaPad Z560...
Lenovo Z560 laptop battery charge drops from 50% down to 7% suddenly. And after that, i need to charge the laptop where it gets charged till 99% only. What is the problem i am facing now?. I purchased the...
Dec 30, 2010 | Lenovo IdeaPad Z560 Notebook
Computers & Internet Logo
62 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
